PartDesign Fillet tool
Re: PartDesign Fillet tool
Each time you add something (edge/face), is there a check made to know if the fillet will work ?
- adrianinsaval
There is no way to do that AFAIK, the arguments are just passed to occt once you disable Add mode and it attempts to fillet.Shalmeneser wrote: ↑Tue Mar 21, 2023 11:33 pm Each time you add something (edge/face), is there a check made to know if the fillet will work ?
I know, but do we need to wait until the end of the action to know if it's ok (someone was speaking of shadowing the result (iterativly ?)).
Actually everytime you add something, the fillet is recomputed. There is even a function that hide the body if it failed :
So we can use this isError() when something is selected.
void TaskDressUpParameters::hideOnError()
App::DocumentObject* dressup = DressUpView->getObject();
if (dressup->isError())
hideObject();
else
showObject();
PR is ready if you want to try it out : https://github.com/FreeCAD/FreeCAD/pull/8990
Or try with the eyes :
Big improvement !
