Chamfer fail to create
I have restarted free cad but unable make Chamfer on whole object
- bitmap.jpg (267.29 KiB) Viewed 720 times
- Champfer_error3.FCStd
- (9.37 KiB) Downloaded 10 times
- Champfer_error2.FCStd
- (11.76 KiB) Downloaded 12 times
- Champfer_error.FCStd
- (55.28 KiB) Downloaded 12 times
Re: Chamfer fail to create
Why three files? What exactly should we look at?
I have this issue constantly today on all imported SVG vector path. so If any one can create chamfer on those whole objects ?
Have Imported from SVG created in corel. then exported SVG using Inkspace. So idk what I should look for either
- papyblaise
the profile being made of B-spline, all chamfers are impossible,
- papyblaise
a workaround if you can't (want) to use simple curves, is to make a first one slightly larger with simple curves and to remove (Pocket) the B-spline profile
- chanfer.JPG (29.7 KiB) Viewed 622 times
- chanfer.FCStd
- (200.15 KiB) Downloaded 8 times
The B-splines don't seem to be a problem, although I had already replaced the straight ones before testing further. The final problem are corners like this upper right one:
Here's a proposed using fix still using B-splines for the curves.- Attachments
- Chamfer_cb.FCStd
- (85.77 KiB) Downloaded 11 times
- thomas-neemann
as long as nobody says what something like this is really needed for, it could be a waste of time
- Champfer_SHALM.FCStd
- (138.99 KiB) Downloaded 15 times
- Annotation 2023-03-21 144702.jpg (12.9 KiB) Viewed 553 times
Thanks
It's stone cutting. I end up cuts cut without chamfer, looks like I need remade SVG from 0 if I ever return to this model
- papyblaise
ho yes - RIPIt's stone cutting
