OCCT 7.7.1 is out.
fcaduser
OCCT 7.7.1 is out.
Post by fcaduser »
Syres
Re: OCCT 7.7.1 is out.
Post by Syres »
I thought I'd done something wrong when I ran CMake against OCCT 7.7.1 because it stated found 7.7.0 but it would appear they forgot to update the Standard_Version.hxx https://git.dev.opencascade.org/gitweb/ ... c321c86799
I don't see a tag in the commit log, why do you say 7.7.1 is out?
nervermind, it is there: https://git.dev.opencascade.org/gitweb/ ... ags/V7_7_1
Syres
Post by Syres »
In the last 2 hours someone has realised their mistake https://git.dev.opencascade.org/gitweb/ ... c321c86799
Syres wrote: Tue Mar 21, 2023 10:03 am I thought I'd done something wrong when I ran CMake against OCCT 7.7.1 because it stated found 7.7.0 but it would appear they forgot to update the Standard_Version.hxx https://git.dev.opencascade.org/gitweb/ ... c321c86799
https://git.dev.opencascade.org/gitweb/ ... a529c04f55
I'm guessing you are not using the correct branch
Syres
Post by Syres »
I was using the correct branch it was OpenCascade not checking the version file before releasing it, they are infallible.
sorry missed your post with the update, and the timestamp on the commit too :oops:
fcaduser
Post by fcaduser »
I'm sure my link to tarball was tagged 7.7.1, anyway use the new one given by adianinsaval.
the latest version of freecad in the flathub-beta repo now uses opencascade 7.7.1: https://github.com/flathub/org.freecadw ... D/pull/116
testers welcomed
to enable flathub-beta repo:
flatpak remote-add --if-not-exists flathub-beta https://flathub.org/beta-repo/flathub-beta.flatpakrepo
then install freecad with:
flatpak install flathub-beta org.freecadweb.FreeCAD
user1234
Post by user1234 »
adrianinsaval wrote: Tue May 02, 2023 8:08 pm testers welcomed
Probably a bug, which needs confirmation.
viewtopic.php?t=77612
Greetings
user1234
