Default Home View
Felix D'Kat
Default Home View
Post by Felix D'Kat »
Hi There, I want to ba able to set a default home view like you do in F360 with this button
Is there a way to do that ?
Thanks In advance.
Syres
Re: Default Home View
Post by Syres »
What you're looking for is called Default Camera Orientation, in Edit>Preferences>Display>Navigation as per:
After applying the change the Home command will go to that setting.
Felix D'Kat
Hi Syres
Thanks for the reply
I must be missing something because I keep getting the same view
This is the view I want:
View 1.jpg (835.53 KiB) Viewed 236 times
But I keep getting this:
View 2.jpg (336.23 KiB) Viewed 236 times
Maybe it's because the XYZ indicator is the wrong way up ?
Thanks.
Felix D'Kat
Never Mind I worked it out, I was missing the CUSTOM camera view tab
Cheers
