Attached is the project of a 90 degree angle bracket. The pic shows 3 views.
#1 and #2 show the from and side view of the bracket (also from the project file)
#3 shows the revised model
Question:
is it easier to slice the bracket to move the bottom of the bracket and re-attach OR create a new model as shown in #3?
hope this makes sense
Do I Slice or re-create model?
- Screen Shot 2023-03-20 at 9.01.10 PM.png (47.74 KiB) Viewed 687 times
- T-Track-Bracket.FCStd
- (45.84 KiB) Downloaded 11 times
Re: Do I Slice or re-create model?
Assuming you wanted the widths to match, it is easier to make again.
- T-Track-Bracket-EW.FCStd
- (27.89 KiB) Downloaded 9 times
You should use axis more cleverly.
- T-Track-Bracket_SHALM.FCStd
- (33.24 KiB) Downloaded 11 times
- Capture d’écran 2023-03-21 070951.jpg (43.62 KiB) Viewed 627 times
- papyblaise
just modify the length of the sketch, and of the slot if necessary
- T.JPG (9.97 KiB) Viewed 584 times
Another lesson learned. So no need to use Datum Planes?
Need to use Datum Planes :
* for mirror
* when multiple sketches need to have same placement
* when a sketch need Rotation THEN offset (attachment do offset THEN rotation)
* when you want to show the plane
* for mirror
thankx you !!Shalmeneser wrote: ↑Tue Mar 21, 2023 10:28 pm Need to use Datum Planes :
* for mirror
I have a slight twist to this bracket that i just realized.edwilliams16 wrote: ↑Tue Mar 21, 2023 4:42 am Assuming you wanted the widths to match, it is easier to make again.
this bracket is for this inside of a bass drum. There will be 2 for the top lugs and 2 for the bottom lugs. If I may Assume not knowing anything about drumming, see pic 1
The brackets will hold metal uprights. I know i can angle the uprights to align, but rather have the brackets angled so the metal uprights are square to the brackets. So, I decided to make the bracket as 2 pieces (pic 2), the existing angle bracket and the other attachment that can pivot. this allows more precise movement and alignment between the top and bottom bass drum lugs.
i take a stab at it. Il get back if i have any issues.
thankx very much for your great work on it for me!!
- Screen Shot 2023-03-22 at 5.50.02 PM.png (36.82 KiB) Viewed 276 times
- Screen Shot 2023-03-22 at 5.47.28 PM.png (44.87 KiB) Viewed 277 times
