help deciding
men132
help deciding
Post by men132 »
https://wiki.freecad.org/FEM_Install
Netgen
what should I write instead. I don't really have enough experience so help would be appreiciated
intelligence is power
Roy_043
Re: help deciding
Post by Roy_043 »
Maybe @uwestoehr can comment.
In general: it is probably better to focus on the sections of the documentation that are about things that you do understand. I personally lack the knowledge to make a serious contribution to, for example, the documentation of the Path and FEM workbenches, and therefore I don't. ;)
uwestoehr
Re: help deciding
Post by uwestoehr »
men132 wrote: Mon Mar 20, 2023 9:30 pm https://wiki.freecad.org/FEM_Install
Netgen
what should I write instead. I don't really have enough experience so help would be appreciated
The Netgen section is wrong. Netgen is not disabled, it works well. It depends on the user what mesher to use. With Netgen it is a bit harder to get a good mesh since one cannot set regions of interest that should be meshed finer:
With Gmsh it is much easier, since you set the max element size and then set submeshes at regions of interests:
Gmsh in FreeCAD offers more options to fine-tune the mesh.
uwestoehr
Re: help deciding
Post by uwestoehr »
uwestoehr wrote: Tue Mar 21, 2023 3:41 pm The Netgen section is wrong. Netgen is not disabled, it works well.
I updated the Netgen section now.
men132
Re: help deciding
Post by men132 »
Roy_043 wrote: Tue Mar 21, 2023 9:39 am In general: it is probably better to focus on the sections of the documentation that are about things that you do understand. I personally lack the knowledge to make a serious contribution to, for example, the documentation of the Path and FEM workbenches, and therefore I don't. ;)
that why I asked. and thanks for the help
