Hello
I want to cut a body with a body that has thickness by part workbench , but this doesn't work.
Is this a bug or a limitation of thickness ? Is there an alternative to do this?
Thanks in advance,
MichaelW
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
* AirPlaneDesign 0.4.0
* CurvedShapes 1.0.4
* Curves 0.5.2
* fasteners 0.4.2
* Help 1.0.3
* Plot 2022.4.17
* WebTools
cut body with thickness body (by part) doesn't work
- test cut thickness.FCStd
- (35.12 KiB) Downloaded 8 times
- papyblaise
Re: cut body with thickness body (by part) doesn't work
a very big first, but we learn every day: how could you make a thikness on all sides
it doesn't matter, it can't work because the result will be composed of 2 separate parts which PartDesign prohibits
- Capture d’écran 2023-03-20 180314.jpg (33.78 KiB) Viewed 426 times
- test cut thickness_ShALM.FCStd
- (35.17 KiB) Downloaded 3 times
- test cut thickness_SHALM2.FCStd
- (19.26 KiB) Downloaded 3 times
- Capture d’écran 2023-03-20 180842.jpg (35.51 KiB) Viewed 420 times
Hello ,
I made the body thicker with part thickness, further I have found an alternative : intersection
see attached file
see attached file
- (62.1 KiB) Downloaded 8 times
Why do you use 3 bodies and 2 workbenches when you could just use 1 body and simple grooves ?
Youi should not use Thickness but Offset.
Your construction is too complex.
Well, these bodies are used in my design so they are present.
