Sheet Metal workbench causes "__dict__ must be set to a dictionary" when loading
Frotz
Post by Frotz »
Partially in reference to viewtopic.php?p=668506, I've found a cause of my trouble with errors like the following when loading a .FCStd file:
<string>(1)<class 'TypeError'>: __dict__ must be set to a dictionary, not a 'NoneType'
I've nailed down a concrete and easy-to-demonstrate cause: Create a body within a part and make that body active. Then make a sketch within the body. Draw something that doesn't form a closed figure, ie a wavy line, then close it. Select the sketch and in the Sheet Metal workbench, click the "Make Base Wall" to make a wavy sheet. Save it. Close that file. Load it. This will provoke a single instance of the error I pasted above.
Attached is something that will provoke this error.
I've identified some other ways to provoke the error, but have yet to come up with a simple demonstration. These focus on making something with the Part workbench, cloning the thing, then putting the original and clones into a union.
OS: Debian GNU/Linux bookworm/sid (MATE/mate)
Version: 0.21.0.32391 (Git)
Build type: Unknown
Hash: a2fec5192343f862ff07702ed1cdf508a4612d0f
Python 3.11.2, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
  * Pyramids-and-Polyhedrons
  * sheetmetal 0.2.61
  * freecad.gears 1.0.0
  * A2plus 0.4.60k
  * fasteners 0.4.55
  * Manipulator 1.5.0
metal-test.FCStd
(25.37 KiB) Downloaded 20 times
Syres
Re: Sheet Metal workbench causes "__dict__ must be set to a dictionary" when loading
Post by Syres »
Frotz wrote: Mon Mar 20, 2023 6:47 am Partially in reference to viewtopic.php?p=668506, I've found a cause of my trouble with errors like the following when loading a .FCStd file:
To stop the error appearing all you need to do is enter something in the Part>Id property value, in my case 12345:
I'm sure the error handling can be improved to give the user a clue as to the origin of the error and a possible solution. I'll throw some time at it over the next couple of days and if I'm struggling I'll raise an Issue on Github.
Syres
Post by Syres »
This took some tracking down but the new Log message rather than Error is:
PropertyPythonObject::fromString(): repr is null for object <class 'SheetMetalBaseCmd.SMBaseBend'>
which would only be used by the developers if something actually did not work so a new user would not see it as Log messages are not enabled by default.
@openBrain do you think this https://github.com/FreeCAD/FreeCAD/comp ... D:patch-71 is acceptable?
openBrain
Post by openBrain »
Syres wrote: Mon Mar 20, 2023 12:02 pm @openBrain do you think this https://github.com/FreeCAD/FreeCAD/comp ... D:patch-71 is acceptable?
From my point of view it's not ideal. :)
I would have kept this part of the code as is, and place this block
            if (repr == "null") {
                Py::String typestr(this->object.type().str());
                Base::Console().Log("PropertyPythonObject::fromString(): repr is null for object %s\n", typestr.as_string().c_str());
                return;
a bit above in the function, just after :
        if (repr.empty())
            return;
So it's clearer that we handle a special case, and we don't proceed to further computation in this case.
Then other cases where 'res == None' may appear, but we will have the opportunity to get a report and analyze it. ;)
Syres
Post by Syres »
@openBrain OK thanks, that's what I did initially but then changed my mind!!
Frotz
Post by Frotz »
Syres wrote: Mon Mar 20, 2023 10:24 am
What's the hash for the build of FreeCAD you're using? I tried that and the error message still appears.
Syres
Post by Syres »
Frotz wrote: Mon Mar 20, 2023 8:42 pm What's the hash for the build of FreeCAD you're using? I tried that and the error message still appears.
Version: 0.21.0.32394 (Git)
Hash: 431fafc5337976c43bf50aae7bc75b46ee8037c7
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.7.0
  * Silk 1.0.0
  * CurvedShapes 1.0.4
  * Curves 0.6.8
  * PieMenu 1.2.4
  * Plot 2022.4.17
  * AirPlaneDesign 0.4.0
  * fasteners 0.4.54
  * sheetmetal 0.2.59
As a side note, I see your Build Type is Unknown, it's best practice to have the Cmake switch when self compiling to
-DCMAKE_BUILD_TYPE=Release
especially with regard to some libraries' performance or
-DCMAKE_BUILD_TYPE=Debug
if you're debugging. https://wiki.freecad.org/Compile_on_Linux#Configuration
Hopefully the proper error handling PR will get merged later this week and all this will no longer be relevant.
Syres
Post by Syres »
Syres
Post by Syres »
openBrain wrote: Mon Mar 20, 2023 1:36 pm a bit above in the function, just after :
        if (repr.empty())
            return;
I'm going to confirm once my compiling finishes but looks like this has caused a major regression in Path Wb, see viewtopic.php?t=77032
Just before the actual errors freman reported, this is shown:
14:41:56  PropertyPythonObject::fromString(): repr is null for object <class 'Path.Main.Gui.Job.ViewProvider'>
14:41:56  PropertyPythonObject::fromString(): repr is null for object <class 'Path.Base.Gui.SetupSheet.ViewProvider'>
14:41:56  PropertyPythonObject::fromString(): repr is null for object <class 'Path.Tool.Gui.Bit.ViewProvider'>
Which makes me think those three viewprovider objects would normally carry on through the code rather than now returning 'early'.
