Problems with SVG imports whith Rectangles
tobiasfalk
Post by tobiasfalk »
I do not know if this is a Problem of FreeCAD TD or Qt but when importing SVG's and the rectangle with is set in mm the size in FreeCAF TD is way of.
The top is with the with writen without a unit:
<rect x="5mm" y="2.5mm" width="10" height="5"/>
The bottom is with mm as unit:
<rect x="5mm" y="2.5mm" width="10mm" height="5mm"/>
Re: Problems with SVH imports whith Rectangles
tobiasfalk wrote: Sat Mar 18, 2023 9:04 am when importing SVG's and
Please correct the title in case you mean "SVG".
wandererfan
Re: Problems with SVG imports whith Rectangles
Post by wandererfan »
tobiasfalk wrote: Sat Mar 18, 2023 9:04 am I do not know if this is a Problem of FreeCAD TD or Qt but when importing SVG's and the rectangle with is set in mm the size in FreeCAF TD is way of.
Hard to say without the svg file to look at, but my guess would be that the lines are not using mm as the unit, so they use px.
tobiasfalk
Here are the two files that I used, the only diference is the line that I showed in the firts kommend, the FreeCAD Projektfile and two pictures to display it a bit better.
In the FreeCAD File and the TD Page I added a 5mm Cube to show that all the other things are scaled correctly, for this the page sclae is 1:1.
Here is the whole SVG Code for those two:
Resistor_mmAsWithAndHight:
<?xml version="1.0" encoding="UTF-8"?>
<svg width="20mm" height="10mm" version="1.1" viewBox="0 0 20mm 10mm" xmlns="http://www.w3.org/2000/svg">
    <description    name="Resistor"
                    designator="R"
                    description="This is the Simbol the normal resistor"
                    name-alias="Widerstand"
                    symbol-alias="Resistor_US.svg"/>
    <g stroke="#000000" fill="none" stroke-width=".35mm" stroke-linecap="round">
        <line x1="0mm" x2="5mm" y1="5mm" y2="5mm" />
        <pin pin="1" x="0mm" y="5mm" type="electric" e-type="passiv"/>
        <line x1="15mm" x2="20mm" y1="5mm" y2="5mm" />
        <pin pin="2" x="20" y="5" type="electric" e-type="passiv"/>
    </g>
</svg>
Resistor_noUnitAsWithAndHight:
                    designator="R"
    </g>
</svg>
The FreeCAD version I used:
  * 3DfindIT 1.2.0
  * A2plus 0.4.56a
  * AirPlaneDesign 0.4.0
  * Assembly3 0.11.4
  * Assembly4 0.11.10
  * CADExchanger
  * cadquery_module
  * CurvedShapes 1.0.4
  * dxf-library
  * DynamicData 2.46.0
  * ExplodedAssembly
  * fasteners 0.3.40
  * fcgear 1.0.0
  * FeedsAndSpeeds 0.5.0
  * FEM_FrontISTR 0.1.0
  * FreeCAD_Electric
  * FreeCAD_Schematics
  * GDML 2.0.0
  * kicadStepUpMod 10.11.7
  * Plot 2022.4.17
  * pyrate
  * Render 2022.2.0
  * sheetmetal 0.2.56
  * Ship 2022.4.11
  * SteelColumn
  * ThreadProfile 1.82.0
  * timber
  * trails 2022.1.0
Resistor_mmAsWithAndHight.svg
(823 Bytes) Downloaded 32 times
Resistor_noUnitAsWithAndHight.svg
(819 Bytes) Downloaded 30 times
problem.FCStd
(21.13 KiB) Downloaded 28 times
tobiasfalk
As problem check I also opened both of them in Firefox and Edge:
Left: Resistor_mmAsWithAndHight; Right: Resistor_noUnitAsWithAndHight
wandererfan
tobiasfalk wrote: Sun Mar 19, 2023 5:38 pm
It is getting late here - are we investigating the size of the resistor body or the leads not being attached to the body? :?
wandererfan
I don't know enough about Svg to explain it, but I managed to make a symbol that comes very close to being 10 x 5.
Resistor_10x5mm.svg
(846 Bytes) Downloaded 34 times
tobiasfalk
The Problem is with the interpretation of the with and height. If a mm is in the with or hight it should be interprated as mm and if not as px. The problem is that if no unit is set than it is interprated as mm and if mm is added the size is multiplyed by 3.7795, witch is the ratio betwen px and mm. This is why I added the Pictures of how Edge and Firefox interprates them.
tobiasfalk
This dous not occur for example with cirles and there radius(r):
    <description    name="Voltmeter"
                    designator="V"
                    description="This is the Simbol for a voltmeter"/>
        <circle cx="10mm" cy="5mm" r="5mm" stroke="black" />
        <text x="10mm" y="7.6mm" font-family="osifont" font-size="7mm" fill="black" stroke="black" text-anchor="middle" always-horizontal="true">V</text>
    </g>
</svg>
The line of the cirle:
wandererfan
If I remove the scaling code, and just set the scale to 1.0, I get this:
which looks like 12 x 6 instead of 10 x 5.
