If I am not getting anything wrong (again)...
It is very strange (although understandable) that the macro ADD_PROPERTY_TYPE calls Property::setValue() when Property itself has no setValue member function.
I do understand the convenience, though.
I think some classes do define a dummy setValue just to make this macro happy.
Is it a bad idea to have an ADD_PROPERTY_TYPE_NO_DEFAULT?
There is no Property::setValue().
- andrecaldas
Re: There is no Property::setValue().
The Property class is abstract, so you don't create instances of Property class, but objects of derived classes such as those defined in PropertyStandard.h, which have a setValue function member.
- andrecaldas
The idea of an abstract class is to provide an interface. There is no Property::setValue. Not even virtual.marioalexis wrote: ↑Sat Mar 18, 2023 2:06 am The Property class is abstract, so you don't create instances of Property class, but objects of derived classes such as those defined in PropertyStandard.h, which have a setValue function member.
Personally, I do not think there should be one. And I am not advocating for it. But if it is not part of the interface, the ADD_PROPERTY_TYPE should not assume there is one.
One solution (to a non-existing-problem, I know) is to have a comment before the definition of ADD_PROPERTY_TYPE explaining the situation, plus an alternative that does not call setValue.
It seems that there are classes derived from Property that define a setValue just to make the macro "happy". For example, PropertyListsT defines a very strange setValue.
Most of those property classes should probably have a very suitable default value you don't need to set. It is strange that they have to call ADD_PROPERTY_TYPE, using things like (nullptr, nullptr).
