Problems importing DXF with OpenSCAD
keithsloan52
Post by keithsloan52 »
@chennes Please could you take look at https://github.com/KeithSloan/OpenSCAD_ ... /issues/10 as I get the same problem with the standard importer.
Image 17-03-2023 at 20.21.jpg (55.12 KiB) Viewed 1042 times
opening /var/folders/cj/z259fmwd41dgzl8mq8nppwd40000gn/T/../../../../../../Users/keithsloan/Downloads/testbend.dxf...
20:17:54  ----------------
20:17:54  Layer
20:17:54  name: 0
20:17:54  line_color: (0.0, 0.0, 0.0)
20:17:54  line_width: 2.0
20:17:54  draw_style: Solid
20:17:54  transparency: 0
20:17:54  drawing 106 lines...
20:17:54  Layer
20:17:54  name: Layer 1
20:17:54  draw_style: None
20:17:54  typecheck[make_layer]: 'None' is not <class 'str'>
20:17:54  Wrong input: must be 'Solid', 'Dashed', 'Dotted', or 'Dashdot'.
20:17:54  Traceback (most recent call last):
20:17:54    File "/Applications/FreeCAD_0.20.2.app/Contents/Resources/Mod/OpenSCAD/OpenSCADCommands.py", line 404, in addelement
20:17:54      importCSG.insert(tmpfilename,doc.Name)
20:17:54    File "/Applications/FreeCAD_0.20.2.app/Contents/Resources/Mod/OpenSCAD/importCSG.py", line 167, in insert
20:17:54      processcsg(filename)
20:17:54    File "/Applications/FreeCAD_0.20.2.app/Contents/Resources/Mod/OpenSCAD/importCSG.py", line 192, in processcsg
20:17:54      result = parser.parse(f.read())
20:17:54    File "/Applications/FreeCAD_0.20.2.app/Contents/Resources/lib/python3.10/site-packages/ply/yacc.py", line 333, in parse
20:17:54      return self.parseopt_notrack(input, lexer, debug, tracking, tokenfunc)
20:17:54    File "/Applications/FreeCAD_0.20.2.app/Contents/Resources/lib/python3.10/site-packages/ply/yacc.py", line 1120, in parseopt_notrack
20:17:54      p.callable(pslice)
20:17:54    File "/Applications/FreeCAD_0.20.2.app/Contents/Resources/Mod/OpenSCAD/importCSG.py", line 846, in p_import_file1
20:17:54      p[0] = [process_import_file(filen,ext,p[3]['layer'])]
20:17:54    File "/Applications/FreeCAD_0.20.2.app/Contents/Resources/Mod/OpenSCAD/importCSG.py", line 864, in process_import_file
20:17:54      obj=processDXF(fname,layer)
20:17:54    File "/Applications/FreeCAD_0.20.2.app/Contents/Resources/Mod/OpenSCAD/importCSG.py", line 927, in processDXF
20:17:54      face = importDXFface(filename,layer,doc)
20:17:54    File "/Applications/FreeCAD_0.20.2.app/Contents/Resources/Mod/OpenSCAD/OpenSCAD2Dgeom.py", line 484, in importDXFface
20:17:54      layers = importDXF.processdxf(doc,filename,False,False) or importDXF.layers
20:17:54    File "/Applications/FreeCAD_0.20.2.app/Contents/Resources/Mod/Draft/importDXF.py", line 2255, in processdxf
20:17:54      newob = addObject(shape, "Line", line.layer)
20:17:54    File "/Applications/FreeCAD_0.20.2.app/Contents/Resources/Mod/Draft/importDXF.py", line 1978, in addObject
20:17:54      lay = locateLayer(layer)
20:17:54    File "/Applications/FreeCAD_0.20.2.app/Contents/Resources/Mod/Draft/importDXF.py", line 349, in locateLayer
20:17:54      newLayer.Label = wantedLayerName
20:17:54  AttributeError: 'NoneType' object
has no attribute 'Label'
testbend.dxf
(7.03 KiB) Downloaded 12 times
testbend2.dxf
(7.04 KiB) Downloaded 12 times
imm
Re: Problems importing DXF with OpenSCAD
Post by imm »
Testbend.dxf imported fine in FreeCAD v0.21
Please remember to click on the 'Draft' workbench to ensure that module is loaded before you do your import....or go to preferences and ensure it is loaded at the time you start FreeCAD.
keithsloan52
imm wrote: Fri Mar 17, 2023 11:13 pm Testbend.dxf imported fine in FreeCAD v0.21
Sorry but I don't think you picked up on the issue. The problem is that the file does not import when using the OpenSCAD function import and gives the error. This would be a problem if the dxf file was being used as part of a more complicated scad script.
The OpenSCAD importer code has
def process_import_file(fname, ext, layer):
    from OpenSCADUtils import reverseimporttypes
    if printverbose: print("Importing : "+fname+"."+ext+" Layer : "+layer)
    if ext.lower() in reverseimporttypes()['Mesh']:
        obj=process_mesh_file(fname, ext)
    elif ext.lower() == 'dxf':
        obj=processDXF(fname, layer)
    elif ext.lower() == 'svg':
        obj=processSVG(fname, ext)
    else:
        raise ValueError("Unsupported file extension %s" % ext)
    return(obj)
So assumes the file has a layer
imm
Post by imm »
The last few lines of your error posting indicate that the OpenSCAD module called on the Draft module functions to process the code.
You will need the Draft module library initialized before you run your OpenSCAD script.
keithsloan52
imm wrote: Sat Mar 18, 2023 10:14 am The last few lines of your error posting indicate that the OpenSCAD module called on the Draft module functions to process the code.
The problem is NOT a failure of initializing the Draft module.
If I add a few diag prints I get
11:05:16  Processing : /Users/keithsloan/Downloads/testImport.csg
11:05:16  Using Alternate OpenSCAD Importer
11:05:16  Doc testImport useMaxFn 16
11:05:16  Import File {'file': 'testBend.dxf', 'layer': 'Layer1', 'origin': [0.0, 0.0], 'scale': '1', 'convexity': '1', '$fn': '0', '$fa': '12', '$fs': '2', 'timestamp': '1679136770'}
11:05:16  Process DXF file
11:05:16  File Name : testBend
11:05:16  Layer : Layer1
11:05:16  PathName : /Users/keithsloan/Downloads
11:05:16  DXF Full path : /Users/keithsloan/Downloads/testBend.dxf
11:05:16  opening /Users/keithsloan/Downloads/testBend.dxf...
11:05:16  ----------------
11:05:16  Layer
11:05:16  name: 0
11:05:16  line_color: (0.0, 0.0, 0.0)
11:05:16  line_width: 2.0
11:05:16  draw_style: Solid
11:05:16  transparency: 0
11:05:16  drawing 106 lines...
11:05:16  Layer
11:05:16  name: Layer1
11:05:16  draw_style: None
11:05:16  typecheck[make_layer]: 'None' is not <class 'str'>
11:05:16  Wrong input: must be 'Solid', 'Dashed', 'Dotted', or 'Dashdot'.
11:05:16  Traceback (most recent call last):
  File "/Users/keithsloan/Library/Application Support/FreeCAD/Mod/Alternate_OpenSCAD/./importCSG.py", line 108, in open
    processCSG(doc, filename)
  File "/Users/keithsloan/Library/Application Support/FreeCAD/Mod/Alternate_OpenSCAD/./importCSG.py", line 176, in processCSG
    p.callable(pslice)
  File "/Users/keithsloan/Library/Application Support/FreeCAD/Mod/Alternate_OpenSCAD/./importCSG.py", line 901, in p_import_file1
  File "/Users/keithsloan/Library/Application Support/FreeCAD/Mod/Alternate_OpenSCAD/./importCSG.py", line 921, in process_import_file
  File "/Users/keithsloan/Library/Application Support/FreeCAD/Mod/Alternate_OpenSCAD/./importCSG.py", line 1020, in processDXF
  File "/Users/keithsloan/Library/Application Support/FreeCAD/Mod/Alternate_OpenSCAD/./OpenSCAD2Dgeom.py", line 485, in importDXFface
<class 'AttributeError'>: 'NoneType' object has no attribute 'Label'
If one looks at the significant part
11:05:16  Layer
What is causing the error is for Layer1 it finding a draw_style of None
It processes the first line ( not in layer1 ) so Draft has been initialized.
keithsloan52
I think there maybe an error in Draft importDXF that is not setting a default for the line type in a given Layer
mconsidine
Post by mconsidine »
I'm the original poster on this problem that Keith references.
Firstly:
OS: Linux Mint 21 (X-Cinnamon/cinnamon)
Version: 0.21.0.32346 (Git)
Hash: db65bb751d347d81128658f5de352a9d4b4d0481
Python 3.10.6, Qt 5.15.3, Coin 4.0.1, Vtk 9.1.0, OCC 7.6.3
  * toSketch 1.0.1
  * Alternate_OpenSCAD 1.0.0
  * Render 2023.2.2
  * Manipulator 1.5.0
  * Help 1.0.3
  * POV-Ray-Rendering
  * MeshRemodel 1.8919.0
  * freecad.gears 1.0.0
  * fasteners 0.4.55
  * Silk 1.0.0
  * Dracula 0.0.2
  * Curves 0.6.8
  * ThreadProfile 1.84.0
Also, I am using a compile of the current "master" version of openSCAD
Attached files from GIMP (GIMP 2.10.34) and Inkscape 1.3-dev (b66badc, 2023-02-03) AppImage:
- testbend_filled.jpg comes from GIMP
- testbend_R12.dxf, testbend_plain.svg, testbend_inkscape.svg come from Inkscape
via Open, Trace Bitmap and Save As operations
- testbend_exportascsg.csg is Export As CSG output from OpenSCAD, after this
line in OpenSCAD
import("testbend_R12.dxf");
- testbend_exportfromOpenSCAD.dxf, testbend_exportfromOpenSCAD.svg are similar outputs
In FreeCAD, using OpenSCAD WB:
These don't work selecting "Add OpenSCAD Element":
//Version A:
//[...]importCSG.py", line 900, in p_import_file1
// p[0] = [process_import_file(filen,ext,p[3]['layer'])]
import("/home/matt/Downloads/3D_design_files/testbend_R12.dxf");
//Version B:
//draws one line then fails, ending with
//File "[...]/Mod/Draft/importDXF.py", line 346, in locateLayer
// newLayer.Label = wantedLayerName
// AttributeError: 'NoneType' object has no attribute 'Label'
import("/home/matt/Downloads/3D_design_files/testbend_R12.dxf",layer="");
//Version C:
//fails with same error from Version A
import("/home/matt/Downloads/3D_design_files/testbend_inkscape.svg");
These succeed, but only with an optional(?) OpenSCAD parameter whose value can be any string it seems. Otherwise they fail with Error A...
//Saved as Inkscape SVG format:
import("/home/matt/Downloads/3D_design_files/testbend_inkscape.svg",layer="");
//Saved as Plain SVG format:
import("/home/matt/Downloads/3D_design_files/testbend_plain.svg", layer="blah");
If I save this
  import(file = "./testbend_inkscape.svg", origin = [0, 0], scale = 1, convexity = 1, $fn = 0, $fa = 12, $fs = 2, timestamp = 1679080119);
as testbend_exportascsg.csg and select File -> Open then the effort fails regardless of the importCSG option chosen. Note that this does not have "layer" specified, as this is how it comes from OpenSCAD
So, if I edit that file and save it with
  layer=""
added, then *both* import options via File -> Open succeed.
Complicating matters even more, the following line in Add OpenSCAD Element works
  import("/home/matt/Downloads/3D_design_files/testbend_exportfromOpenSCAD.dxf", layer="");
even though importing a DXF generated from Inkscape in the same manner (as above) does not. Ie the DXF generated by OpenSCAD was read in.
I don't know where to begin to figure out where the problem is. Simply put, I expected that if I could directly open a DXF file then I would be able to import same, as I can in OpenSCAD. The workaround (for me) appears to be to use .SVG files as both OpenSCAD and FC seem to be able to import them, even though in FC I need to use a keyword (layer) that is not included in .CSG output from OpenSCAD. For context, the genesis of the problem is an effort to port a large OpenSCAD script to FC and some shapes - which are drawn on blueprints - are more easily taken as bitmaps that are then extruded.
HTH and thanks in advance for any constructive suggestions.
mconsidine
testbend_files.zip
(53.66 KiB) Downloaded 11 times
imm
Post by imm »
from what I can see there is a problem with the importDXF.py in the draft module that is arbitrarily being used for import.
if you insert the following at line 336 it should resolve your issue.
    # layers is a global variable.
    # It should probably be passed as an argument.
    # ---> snip below is to be inserted here  .....
    if isNone(wantedLayer):
        wantedLayer='0'
    # ---> snip end of inserted text .....
    wantedLayerName = decodeName(wantedLayer)
code claims to have a default value assigned, but if there was such it has been removed.
keithsloan52
imm wrote: Thu Mar 23, 2023 12:26 am from what I can see there is a problem with the importDXF.py in the draft module that is arbitrarily being used for import.
        wantedLayer='0'
"from what I can see there is a problem with the importDXF.py in the draft module that is arbitrarily being used for import."
Draft is being used because the OpenSCAD importer needs to import to Face, where as the standard FC importer is coded to import to a Document.
Thanks for the fix, hopefully @chennes can test and merge into Draft.
chennes
Post by chennes »
I've submitted a PR with the suggested fix (is there anything special about using "0" as the default layer name?). https://github.com/FreeCAD/FreeCAD/pull/9021
Chris Hennes
Pioneer Library System
