Removing Image wb
chennes
Re: Removing Image wb
Post by chennes »
I had not yet created an Issue for this, but it seems there is consensus at least on the forums here that this is an “identified and agreed upon problem”. I vote we get an issue opened, finish this discussion, and then start coding 😎.
Chris Hennes
Pioneer Library System
sliptonic
Post by sliptonic »
chennes wrote: Fri Mar 17, 2023 9:06 pm I had not yet created an Issue for this, but it seems there is consensus at least on the forums here that this is an “identified and agreed upon problem”. I vote we get an issue opened, finish this discussion, and then start coding
Let's co-opt this issue: https://github.com/FreeCAD/FreeCAD/issues/8556
aapo wrote: Fri Mar 17, 2023 8:59 pm
Ooh, that's a nice idea! :D Then after opening the file, the toolbox/dialog/whatever could pop up and you'd be able to input your offset, plane (XY/XZ/YZ) and scale. And doubleclicking the object in the tree would just reopen the same dialog. So, no functionality would be lost and it'd be quite clutter-free and convenient.
Should the initial plane be aligned with the current camera position? That seems intuitive to me. The user should always be able to align it via the task panel.
I like the ideas of using the well known import function plus a dedicated task dialog for scaling.
yes using import seems like the most discoverable solution and it makes perfect sense
paddle
Post by paddle »
Well sounds good then. I'll get started.
For the placement:
- Automatically it would start at current view plane
- Then the imageplane taskbox would have something similar to the feature pick of PartDesign_NewSketch. Or the attachement taskbox. (those needs to be harmonized btw, no reason we would need several)
I created an issue to discuss it further about it's technical questions :
https://github.com/FreeCAD/FreeCAD/issues/8945
paddle wrote: Sat Mar 18, 2023 6:35 am For the placement:
That would be different from other imports. And if we already make it different, shouldn't we rather show the planes selection dialog which is shown now? More than 95% (a guess) if not more, of the images I have seen here are on one of the main planes.
Zolko
Post by Zolko »
paddle wrote: Sat Mar 18, 2023 6:35 am Well sounds good then. I'll get started.
If you're dealing with this problem, could you please also consider to solving another issue with images: that they're not visible from the back-side, we only get a black rectangle. It would be very useful – and absolutely intuitive – to have a semi-transparent viewpoint from the back of the image.
xtemp09
Post by xtemp09 »
paddle wrote: Fri Mar 17, 2023 2:01 pm- The image viewer is removed. All tools from the toolbar are removed.
I'm just watching 230302 - freecad and free cae users conference - day 2 of 3-001.mp4 and in this video at 02:18:12 POV-Ray rendering result is shown as an image in FreeCAD in a separate tab.
Perhaps, removal of image viewer should be reconsidered. I think rendering result should be shown as image in a separate tab, instead of being opened by external tool.
chrisb wrote: Fri Mar 17, 2023 11:31 pm I like the ideas of using the well known import function plus a dedicated task dialog for scaling.
+1 for me, standard File > Open plus additional dialog to set things.
But please think something about Scripting something easy when importing an img object something simple as:
img = FreeCAD.import("../images/images.png")
img.setPlane = ...
img.setScale = ...
img.Placement = ...
# and eventually
img.getPlane
img.getScale
bambuko
Post by bambuko »
Zolko wrote: Sat Mar 18, 2023 8:20 am It would be very useful – and absolutely intuitive – to have a semi-transparent viewpoint from the back of the image.
very useful indeed
glad that someone agrees with me ;)
it's already possible (see my post earlier in this thread), by using backlight (preferences) and image transparency (image appearance)
