I want to enter different temperatures at Inlet in OpenFOAM, is that possible?
I have defined a table and entered a list for temperatures, but did not work
Inlet, Temperature
Moderator: oliveroxtoby
Inlet, Temperature
- Screenshot 2023-03-15 103827.png (19.61 KiB) Viewed 1190 times
Re: Inlet, Temperature
It all comes down to what is written in case files. I think that something like this in the T file could work:
Give it a try. Of course, enter your values. Some additional changes might be necessary.
inlet
type uniformFixedValue;
uniformValue table
(0.0 290.0)
(1.0 340.0)
It worked, thank you
Great, did you have to modify anything in the code that I posted or was it fine ?
I want to say, the first variable is "time" and the second variable is "temperature[K]"
I want to make a coupling between CFD (cfdof) and FEM. Is it possible to set different Heat Flux in ConstraintHeatflux?
I will take temperature from cfd and put it in FEM. Do you have a idea for this coupling?
It’s not supported. You would have to do this manually (with some scripts) or use the preCICE tool for multiphysics analysis.
How can i do this manually?
Schoud i change inp.file?
- Screenshot 2023-03-29 221355.png (47.97 KiB) Viewed 957 times
Automation with scripts would be necessary. You would have to export temperatures from CFD results and map them to mesh for FEM in CalculiX. The problem is that the results would have to be interpolated and then you could define a temperature field with keywords (again using some automation because you will need lots of keyword lines defining temperature at each node). ParaView may help with this process, at least partially: https://discourse.paraview.org/t/interp ... -mesh/5479Ehsandehghani wrote: ↑Wed Mar 29, 2023 8:17 pm How can i do this manually?
