Rotating Wall Velocity Error of a Fan
Moderator: oliveroxtoby
hooshsim
Post by hooshsim »
Hi, all
I am trying to simulate a rotating fan installed in a box. The model file is setup correctly and a mesh is generated without any error. I have also updated the "U" file in the "0" directory to include the fan speed as outlined below. Once I submit the model for the solution, I get an error as shown in the attached sfile.
Can someone please take a look at my model and tell me what the issue could be here. My model is very similar to this tutorial on Youtube. https://youtu.be/Q10MbSFEiEM
Thanks
/*--------------------------------*- C++ -*----------------------------------*\
|                Generated by the CfdOF workbench for FreeCAD                 |
|                  https://gitlab.com/opensimproject/CfdOF                    |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0.0 0.0 0.0);
boundaryField
    inlet
        type            flowRateInletVelocity;
        massFlowRate    1.0;
        rho             rho;
        rhoInlet        1.2;
        value           $internalField;
    outlet
        type        pressureInletOutletVelocity;
    wall
        // movingWallVelocity reduces to fixedValue if the mesh is not moving
        type        movingWallVelocity;
        value       uniform (0 0 0);
    fan
        // Specified velocity, only component tangential to wall is used
	type	rotatingwallvelocity;
	origin	(0. 0. 0.);
     	axis  	(0. 0. -1.);
     	omega	constant 430;
    defaultFaces
        type        slip;
NewJoker
Re: Rotating Wall Velocity Error of a Fan
Post by NewJoker »
This question should be placed in the FEM —> CfdOF subforum.
Which lines are the ones to which the error refers ?
hooshsim wrote: Fri Mar 17, 2023 12:12 am /*--------------------------------*- C++ -*----------------------------------*\
Please edit your post and put the code in code tags using the button </>. That makes the post easier to read and shows immediately the indentations.
hooshsim
Post by hooshsim »
NewJoker wrote: Fri Mar 17, 2023 8:03 am This question should be placed in the FEM —> CfdOF subforum.
Error refers to the lines below patch name "Fan"
NewJoker
Post by NewJoker »
hooshsim wrote: Fri Mar 17, 2023 11:17 am Error refers to the lines below patch name "Fan"
Try changing it to this:
	origin	(0. 0. 0.);
     	axis  	(0. 0. -1.);
     	omega	430;
hooshsim
Post by hooshsim »
NewJoker wrote: Fri Mar 17, 2023 11:28 am
	origin	(0. 0. 0.);
     	axis  	(0. 0. -1.);
     	omega	430;
I tried that first...same error but, at different line under the same patch name.
Trying to attach the file but it's too big. How do I reduce the file size for posting? Appreciate your help.
NewJoker
Post by NewJoker »
hooshsim wrote: Fri Mar 17, 2023 11:45 am Trying to attach the file but it's too big. How do I reduce the file size for posting? Appreciate your help.
You could use some hosting website like WeTransfer, Drobpox or Google Drive and paste the link here.
hooshsim
Post by hooshsim »
Here is the link to the model file.
https://drive.google.com/file/d/1351og6 ... sp=sharing
hooshsim
Post by hooshsim »
NewJoker wrote: Fri Mar 17, 2023 12:01 pm
NewJ,
Does the link work out for you? First timer on Google Drive
Thanks
NewJoker
Post by NewJoker »
hooshsim wrote: Fri Mar 17, 2023 12:26 pm Does the link work out for you? First timer on Google Drive
You would also have to set access to "Anyone with the link".
