Is it possible to make a DXF from face data with python code throught the FreeCAD API ?
I cant really find something.
Ill just dump my code as an example, Im filtering out duplicate child solids, then i search for the face object with the highest Area.
Most of the time this should be the basic plane of type Plane.
Would be great if i could also get a complete face with the bends.
import sys
import FreeCAD
import Part
import Import
import json
import decimal
class Test:
def __init__(self, shape,ShapeType, valid, area, volume, length, num_faces):
self.shape = shape
self.ShapeType = ShapeType
self.valid = valid
self.area = area
self.volume = volume
self.length = length
self.num_faces = num_faces
self.face_data = []
for face in self.shape.Faces:
#print(dir(face.Placement.Base))
face_dict = {
"valid": face.isValid(),
# "WhatBeInIt": dir(face),
"area": face.Area,
"volume":face.Volume,
# "isSame": face.isSame(),
# "center_of_mass": face.CenterOfMass,
# "normal": face.normalAt(0.5, 0.5),
# "isClosed": face.isClosed, An error occurred: Object of type 'builtin_function_or_method' is not JSON serializable
# "hashCode": face.hashCode, An error occurred: Object of type 'builtin_function_or_method' is not JSON serializable
"lengte": face.Length,
'X': face.Placement.Base.x,
"Y": face.Placement.Base.y,
"Z": face.Placement.Base.z,
"faces": len(face.Faces),
"num_wires": len(face.Wires),
"num_edges": len(face.Edges),
self.face_data.append(face_dict)
try:
data = Part.Shape()
# data.read("./assets/test/Weldment02-Staander_Midden.stp")
data.read("./assets/test/TestDubbel.stp")
# Read in the STP file and extract the desired lines of text
# with open("./assets/test/Weldment02-Staander_Midden.stp", "r") as f:
with open("./assets/test/TestDubbel.stp", "r") as f:
stp_text = f.readlines()
# Loop through each line in stp_text
product_lines = []
found_occurrence = False
occurrence_lines = []
for line in stp_text:
if "=NEXT_ASSEMBLY_USAGE_OCCURRENCE('" in line:
found_occurrence = True
occurrence_lines.append(line)
elif found_occurrence:
if ";" in line:
product_lines.append("".join(occurrence_lines))
ShapeType = data.ShapeType
valid = data.isValid()
area = data.Area
volume = data.Volume
length = data.Length
# faces = data.Faces
num_faces = len(data.Faces)
num_solids = len(data.Solids)
# Create a Test object with the extracted data
# print(dir(faceCollection), 'what be in it')
test = Test(data,ShapeType, valid, area, volume, length, num_faces)
# Create a list of dictionaries to hold the data for each object
object_list = []
# Append the data for the first object
object_dict = {
"stuknaam": product_lines[-1],
"valid": test.valid,
"opp": round(test.area,2),
"volume": round(test.volume,2),
"lengte": round(test.length,2),
"aantalFaces": test.num_faces,
"subparts": num_solids,
"face_data": test.face_data,
object_list.append(object_dict)
# Initialize the object list
properties_list = []
for i, solid in enumerate(data.Solids):
properties = (round(solid.Area, 2), round(solid.Volume, 2), round(solid.Length, 2), len(solid.Faces), len(solid.Edges))
if properties not in properties_list:
face_collection = []
face_shapes = []
for face in solid.Faces:
area = face.Area
# get the underlying surface of the face
surface = face.Surface
# Het effectieve shape eruit halen voor json.
surface_type = type(surface).__name__
# get the type of the surface
# surface_type = surface.__class__.__name__
face_shapes.append(surface_type)
face_collection.append(area)
max_area = max(face_collection)
max_index = face_collection.index(max_area)
count = face_collection.count(max_area)
derp = face_shapes[max_index]
properties_dict = {
'count': 1,
'valid': solid.isValid(),
'opp': solid.Area,
'volume': solid.Volume,
'length': solid.Length,
'num_faces': len(solid.Faces),
'num_edges': len(solid.Edges),
'faceShape': derp ,
'highestFaceArea': max_area,
'highestFaceAreaCount': count
properties_list.append(properties)
properties_dict['properties'] = properties
properties_dict['sub_objects'] = []
properties_dict['sub_objects'].append(i)
object_list.append(properties_dict)
else:
index = properties_list.index(properties)
properties_dict = object_list[index+1]
properties_dict['count'] += 1
print(json.dumps(object_list)) #print(json.dumps(solids))
except Exception as e:
print("An error occurred:", e)
sys.exit(1)
