Labelling/naming sketcher elements
Re: Labelling/naming sketcher elements
Being to write notes anywhere would be nice. Even if it just overnight to remind where it was left off the previous day.
I often use the Tools>Add text document to add a page where I can make a sort of journal of various things.
One thing I find often in those journals is the why and wherefore of some workaround I used. (We all know workarounds are minimal in FreeCAD, right? )
In addition there are File>Project information
These are not as good as notes on the actual sketches or even around the model. But, it is available now.
I don't think it's about overloading the solver. It's about overloading of concepts and that not every workbench has to provide everything.
Does this mean that you not only want to label sketcher elements but also like to have a journal function in all workbenches to be able to quickly document any workflow and workaround you use?
To keep model size low I would rather have a separate document and save it in the same folder as the model and drawing data (to always have it at hand).
Are you sure? Modelsize has always been a drawback in the past. At least, in this case it is only a tiny one.
The text document is part of the FC file. The FC file is a zip file. It is for the document/project not per workbench.FBXL5 wrote: ↑Sun May 14, 2023 10:40 pm ...Does this mean that you not only want to label sketcher elements but also like to have a journal function in all workbenches to be able to quickly document any workflow and workaround you use?
A text page is going to have very little impact on the size of the FCStd file.
if you don't mind entering them manually, you can always click on a particular point and obtain
them from below the 'Element' sub window ... and enter them into a worksheet (CSV) as you go along.
Format is: (x, y, z).
frcaduser
frcaduser
- lineCoordinates.png (29.64 KiB) Viewed 1049 times
Modelsize for text labeling elements in sketch?!? which % is a drawback for you? 0.000..1%
@FBXL5
Re "overloading"
There is a concept in software design that we call instantiation - if you don't use the object - or field in a data base - it isn't there. If you don't use it - it won't effect you. It won't increase your file size if you don't use it. You will never be exposed to bugs in the feature if you don't use it.
The only possible downside would be it exists in a menu - even this could potentially be turned on and off via a preference setting.
I've used a lot of CAD/simulation packages (14+?)- starting in 1986 - and produced a lot of designs - electronic and mechanical (It was my life) - having text blobs associated with design elements has ALWAYS been important in the workflow. It is even more important to document design features/choices if you work with other people. Part of the job of a design file is to communicate - text is pretty good for that.
There are times when software goes backwards via feature creep - especially in commercial software when the sales force wants a way to sell the next version. This is not one of those times.
Re "overloading"
I would rather have questions that cannot be answered,
than answers that cannot be questioned’
Richard Feynman.
Richard Feynman.
