[Feature idea] More informative tooltips.
- MisterMaker
Re: [Feature idea] More informative tooltips.
Linkstage already has the option to add gifs, and it works. Now we only need a gazzilion gifs.
Gif would be very explanatory and great but they would weight a lot if we have a lot of gifs.
And they need a lot of time to do. Besides they would need to be redone everytime a tool changes.
- MisterMaker
You can still add text instead of a gif with an image, but gifs sre as my opinion easier to make than some text. It's also doesn't need a translation.
With programs like sharex (*for windows) you can very quickly and very easily make a gif.
Yes and no. If the GUI is translated, gifs can/should/must show the translated GUI as well.
- Kartoffelpüre
I stumbled upon this thread. May a suggestion. Could that may be create together with the Wiki?
If you have a wiki page for a feature you may, could create a wiki template that contain a short description of a feature.
That way, Wiki user could enhance and translate Feature descriptions them self. With a closer work with the wiki you may are also able to add help links into feature and also to the tooltip that leads directly to the wiki page.
- Kartoffelpüre
What do you think about my suggestion?
You mean that clicking the tooltip would open a browser tab of the wiki? Or that the tooltip would fetch the first paragraph of the wiki automatically ?
The ? button on taskboxes is an interesting idea.
- Kartoffelpüre
I propose to use it offline. Mark all paragraphs inside the wiki that match the requirement for being a Tooltip text.
I would say that the Wiki need a task that permanently export all the paragraphs into a file that the Freecad compiler could handle to integrate it.
The Question Mark instead should Link to the Wiki.
example:
I assume there is an Initial work that has to be done to auto-detect and mark already existing Descriptions.
example:
<div id="Tooltip">
<span id="Description"></span>
== Beschreibung ==
Das Werkzeug [[Image:PartDesign_Chamfer.svg|24px]] '''PartDesign Fase''' erzeugt Fasen (Abschrägungen) an den ausgewählten Kanten eines Objekts. Es fügt dem Dokument ein '''Chamfer'''-Objekt und den dazugehörigen Repräsentanten in der [[Tree_view/de|Baumansicht]] hinzu.
<div>
- Kartoffelpüre
Found a description for Template system for Mediawiki
https://www.mediawiki.org/wiki/Help:Templates
I assume that this could be used.
It already can. See Preferences_Editor#Help
