[Solved] Get polygons or wires vertices to an array or list
jfc4120
Post by jfc4120 »
I can handle a single vertex if selected. But how do you select an entire polygon (or wire if downgraded) and the the coordinates of all the vertices in a multi list?
I have tried variations of this code:
# -*- coding: utf-8 -*-
import FreeCAD,FreeCADGui
import Draft
import math
from PySide import QtGui
selX = FreeCADGui.Selection.getSelectionEx()
PrintMsg = FreeCAD.Console.PrintMessage
PrintMsg("Objects selected:\n")
for sel in selX:
  if sel.HasSubObjects:
    v = sel.SubObjects[0]
    if v.ShapeType == 'Vertex':
      print(f'SubObject[0] is Vertex at {v.Point}')
      X1 = v.Point.x *  .039370078
      print(X1)
    else:
      print(f'SubObject[0] is a {v.ShapeType}')
      print(X1)
  else:
    v = sel.Object.Shape
      print(f'Object is Vertex at {v.Point}')
      print(X1)
      print('here')
    else:
      print(f'Object is a {v.ShapeType}')
      print(X1)
I also tried code here: viewtopic.php?t=46435
Re: Get polygons or wires vertices to an array or list
Each Shape as a Vertexes property, it is not enough
vtx_array = []
for obj in objects:
 vtx_array.append(obj.Shape.Vertexes)
Provided objects are DocumentObjects with a Shape property.
See:
dir(Part.Shape)
['Edges', 'Faces', ... 'Shells', 'Solids', 'SubShapes', ... , 'Vertexes', ..., 'Wires',
but also:
dir(Part.Wire)
or even:
dir(Part.Edge)
You have a Vertexes list for each entity, so you could make a nested list for each Shape, Wires, Edge so you could have even a multilevel extraction of Vertexes at Shape, Wire and Edge level.
Hope it helps.
jfc4120
Post by jfc4120 »
@onekk None of the above worked, however I found an older post you had:
You had:
select=FreeCADGui.Selection.getSelection()[0]
wire = select.Shape.Wires[0]
for pts in obj.Wires[0].Vertexes:
    print(pts.Point)
Gave error on obj.Wires so I changed to:
for pts in wire.Vertexes:
    #print(pts.Point.x *  .039370078)
    print(pts.Point)
Works great, thanks. :D :idea: :roll:
Edit:
The funny part, I tried it yesterday and gave up, but after looking it over is when I thought to try the:
:oops:
Output:
15:08:46  Vector (-150.06994531332884, -1483.2147216796875, 0.0)
15:08:46  Vector (-1286.6182246097892, 485.34464331676486, 0.0)
15:08:46  Vector (-3559.7147832027104, 485.3446433167651, 0.0)
15:08:46  Vector (-4696.263062499171, -1483.2147216796873, 0.0)
15:08:46  Vector (-3559.7147832027113, -3451.7740866761396, 0.0)
15:08:46  Vector (-1286.618224609791, -3451.7740866761405, 0.0)
jfc4120 wrote: Thu Mar 16, 2023 8:14 pm ...
above code ie the dir() thing should work as they are directly showing the property of an object.
Hovewer
obj.Shape.Wires[0]
provided that obj is a DocumentObject will return a Part.Wire object so it is working, at least for a Wire.
It is all about hierarchy.
I have to check first code (I have told you tha was written using memory) in a real situation.
Let me see tomorrow as probably I have some spare time.
jfc4120
Re: [Solved] Get polygons or wires vertices to an array or list
Post by jfc4120 »
@onekk all is good, as I have working code now. But yes reply if you need to explain something as I am still learning. :?
edwilliams16
Post by edwilliams16 »
@jfc4120
I think you are missing the point of Carlo's post. Suppose you make a number of selections - say a vertex and a face from Object1 and an edge from Object2
sels = Gui.Selection.getSelection()
returns a list of "Selection Objects" in this case two of them, one for Object1 and one for Object2. Assuming they are objects that have a Shape
(ie made by Part, Part Design, Draft etc. not Meshes), then sel[0].Shape and sel[1].Shape contain the topological and geometrical information about the entire objects - BUT - DO NOT contain information about which vertices/edges/faces that were selected - only the objects that contained them.
If for instance, you wanted the location of all the vertices in Object1:
for vertex in sels[0].Shape.Vertexes:
    print(vertex.Point)
Suppose you wanted the vertices on a face by face basis:
for i, face in enumerate(sels[0].Shape.Faces):
    print(f'Face{i+1}')
    for v in face.Vertexes:
        print(v.Point)
Objects have faces, edges and vertexes
Faces have edges and vertexes
Edges have Vertexes
Vertexes have locations (point)
This is what is refered to as Topology
However, suppose you want information about the particular vertex/edge/face/objects(s) you selected - not just the object in which they were contained.
Now we need Gui.Selection.getSelectionEx(), in fact to be compatible with links, you should use Gui.Selection.getSelectionEx('', 0)
In the example above
for sel in Gui.Selection.getSelectionEx('',0):
    print(f'\n{sel.Object.Name}')
    for path in sel.SubElementNames if sel.SubElementNames else ['']:
        subobj = sel.Object.getSubObject(path)
        print(f'   {subobj.ShapeType}')
sel.Object contains the selected object, subobj contains the selected subobject (face/edge/vertex)
replacing subobj = sel.Object.getSubObject(path) with subobj = sel.Object.getSubObject(path, retType = number) returns additional optional information about the subobj like its global Placement. Here's the help:
>>> help(sel.Object.getSubObject)
Help on built-in function getSubObject:
getSubObject(...) method of Part.Feature instance
    getSubObject(subname, retType=0, matrix=None, transform=True, depth=0)
    * subname(string|list|tuple): dot separated string or sequence of strings
    referencing subobject.
    * retType: return type, 0=PyObject, 1=DocObject, 2=DocAndPyObject, 3=Placement
        PyObject: return a python binding object for the (sub)object referenced in
        each 'subname' The actual type of 'PyObject' is implementation dependent.
        For Part::Feature compatible objects, this will be of type TopoShapePy and
        pre-transformed by accumulated transformation matrix along the object path.
        DocObject:  return the document object referenced in subname, if 'matrix' is
        None. Or, return a tuple (object, matrix) for each 'subname' and 'matrix' is
        the accumulated transformation matrix for the sub object.
        DocAndPyObject: return a tuple (object, matrix, pyobj) for each subname
        Placement: return a transformed placement of the sub-object
    * matrix: the initial transformation to be applied to the sub object.
    * transform: whether to transform the sub object using this object's placement
    * depth: current recursive depth
jfc4120
Post by jfc4120 »
@edwilliams16 thanks, I have learned a lot from both of you.
I used his code, just a minor tweak, it works.
I am still not positive when to use: getSelectionEx verses getSelection.
His code used:
select = FreeCADGui.Selection.getSelection()[0]
Whereas in some code:
Like:
selX = FreeCADGui.Selection.getSelectionEx()  ###This top portion is from you.
KOUNT = 0
# added
for sel in selX:
    KOUNT = KOUNT + 1
    X = v.Point.x * .039370078
    Y = v.Point.y * .039370078
    Z = v.Point.z * .039370078
    if KOUNT == 1:
        multlist = [[X, Y, Z]]
    if KOUNT > 1:
        multlist.append([X, Y, Z])
The top portion derived from one of your answers. But as I go, I am picking up more and more. Like above, I resolved by tweaking a previous answer from @onekk .
But again I appreciate the good folks here on the forum who are willing to help. :D
I am also going to experiment with code from your answer. In this case I only wanted to get vertices of a wire and set points there., like:
import FreeCAD, FreeCADGui
import Draft
import math
convert = 25.4
KOUNT = 0
    KOUNT = KOUNT + 1
    X = pts.Point.x * .039370078
    Y = pts.Point.y * .039370078
    Z = pts.Point.z * .039370078
    if KOUNT == 1:
    if KOUNT > 1:
    # print(pts.Point.x *  .039370078)
    print(pts.Point)
print(multlist)
K = KOUNT
for i in range(0, KOUNT):
    K = K - 1
    print('k', K)
    print(multlist[K][0], multlist[K][1], multlist[K][2])
    Draft.makePoint(multlist[K][0] * convert, multlist[K][1] * convert, multlist[K][2] * convert)
edwilliams16
  • getSelection() gives info about the entire object you selected, but not about which particular subobject (vertex,edge,face) you picked.
  • getSelectionEx() also has info about the particular subObject(s) you picked
  • getSelectionEx(0,'') additionally can distinguish between linked copies of selected object/subObject. The previous methods point back to the original.
    This is required, for instance, if you need the global positioning of the linked object/face/vertex/edge.
As their use gets successively more complicated, I usually provide that minimally sufficient for the purposes of the OP.
My previous post is essential understanding for those wanting to use selections in their Macro. I assume it is documented somewhere in the wki, but I have yet to find it.
edwilliams16 wrote: Fri Mar 17, 2023 12:14 am ...
Thanks a lot, I will note down for future references.
Sadly things like these are difficult to find in the Wiki.
Kind Regards
