I have a recent master build and am finding that the expression editor in sketcher is crashing FC and dumping me back to the console.
In the attacked minimal example, open the sketch and edit the length constraint on the side length of the square. Entering all values works as expected.
Now click the ffx icon to go to the expression editor. The numbers 0..9 are accepted, however enter a decimal point and it is not reflected in the expression editor. After a couple of seconds FC crashes, windows close and totally disappears with a coredump . I'm left back at the command console I used to launch FC.
/builddir/build/BUILD/gcc-12.2.1-20221121/obj-x86_64-redhat-linux/x86_64-redhat-linux/libstdc++-v3/include/bits/basic_string.h:1221: std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::reference std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::operator[](size_type) [with _CharT = char; _Traits = std::char_traits<char>; _Alloc = std::allocator<char>; reference = char&; size_type = long unsigned int]: Assertion '__pos <= size()' failed.
Aborted (core dumped)
OS: Fedora Linux 36 (Thirty Six) (LXQt/lxqt)
Version: 0.21.0.32198 (Git)
Hash: f51b2156f35399cab38eef1e957a59ad5a11de66
Python 3.10.10, Qt 5.15.8, Coin 4.0.0, Vtk , OCC 7.6.3
* FreeCAD_Assembly4 0.11.10
* FreeCAD_assembly3
