Dimension Reference Corruption
user1234
Re: Dimension Reference Corruption
Post by user1234 »
@wandererfan : have you a link from this model here, see https://github.com/FreeCAD/FreeCAD/issu ... 1472446823?
Sometimes the extra lines are from the the view direction. Example here this model, see viewtopic.php?style=8&p=669791#p669543.
The view direction have precision issues, the views are per default not |1| or |0| and there are many extra points. When i manually overwrite them, it is normal.
I have seen this regularly. Maybe the view direction in 3D does not give exact directions (since there it does not really matter for the usecase).
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.21.0.32425 (Git)
Hash: bdc704eaa0225f4f2e9918f028451b2453cfe426
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 9.0.1, OCC 7.7.1
  * QuickMeasure 2022.10.28
  * CurvedShapes 1.0.4
  * Curves 0.6.8
Greetings
user1234
wandererfan
Post by wandererfan »
user1234 wrote: Wed Mar 22, 2023 5:13 pm @wandererfan : have you a link from this model here, see https://github.com/FreeCAD/FreeCAD/issu ... 1472446823?
Should be this one ...
Spojnica tutorial.FCStd
(940.22 KiB) Downloaded 26 times
user1234
Post by user1234 »
Thanks!
When editing to straight numbers, some areas are a little bit better, but some are worse.
The hlr act sometimes weird, must be a pita in programming.
Greetings
user1234
