Fillet in Path
Fillet in Path
Hi
I'm trying to set up a fillet operation in the Path workbench by implementing the 3D pocket tool. When I do so I get an error message:
18:04:49 PathPocket.WARNING: Final depth set below ZMin of face(s) selected.
18:04:49 <Path.Area> Area.cpp(1437): hit bottom -0,7,7
18:04:49 <Path.Area> Area.cpp(1437): hit bottom -7,-5.32907e-15,1e-06
18:04:49 <Path.Area> Area.cpp(1564): Discard empty section
What I'm I doing wrong..?
Re: Fillet in Path
Well, the first thing wrong is that you did not say which version of FC you are using. I tried opening with a recent version 0.21 and that failed so I guessed that your file was created with an older version.
More importantly, you have given no clue about what you are trying to do.
I opened your file and created a "Pocket 3D" operation with no problems or errors. I suspect you were trying to select some particular face or faces.
It might be useful to let us in on the secret.
Gene
Re: Fillet in Path
I use freecad 0.20. I was trying to create a fillet path with the 3D pocket tool, on the fillet on the object I attached in the file and got the error message I posted. Didn't mean to puzzle you...
Re: Fillet in Path
I again tried various selections with 3D Pocket and never saw a problem. The tools in your file seem rather large for this object, but they worked.
It seems to me that 3D Surface is a much better choice than 3D Pocket.
I am using version 0.21.0.30454 of FreeCAD. This is one of the last versions that would still open the older-style Path Jobs.
If I was starting by making a new Job I would definitely use the latest available development version of 0.21. Lots of continuing improvements.
Gene
Re: Fillet in Path
Thanks!
I had my freecad set on an other language, might be to cause of the funky naming on my behalf. I'll try the 0.21.xxx version to see whether that sorts things.
Re: Fillet in Path
So I tried the 0.21.xxx version, but without any luck. Here's a picture describing what I would like the do, the fillets are highlighted.
https://www.dropbox.com/s/p74il7uksk18n ... t.bmp?dl=0
I attach two files where I tried to set up an operation to mill the fillets with ball head mill-bits.
Any advice would be appreciated. Thanks!
- testing fillet 021.FCStd
- Trying in FC0.21.xxx
- (33.64 KiB) Downloaded 17 times
- testing fillet 020.FCStd
- Trying in FC 0.20.xxx
- (31.92 KiB) Downloaded 18 times
Re: Fillet in Path
You need 3DSurface for this. The fillet is neither a profile, nor a face, nor a pocket.
Re: Fillet in Path
Aha, so I need an add on for the 3D surfacing. I didn't get that.
Is it this tool: Wiki - Surface? Do you know if there's a smoother way of installing it and get it up and running than the step guide in the wiki?
Thanks!
Re: Fillet in Path
This is as smooth as it gets:
- enable Path experimental
- check Preferences... → Path → Advanced → Enable OCL dependent features
You haven't posted your FreeCAD infos, so I don't know what system you have, but most probably will the opencam library be preinstalled together with FreeCAD.
Re: Fillet in Path
Seems to work, thanks!chrisb wrote: ↑Tue Mar 21, 2023 5:06 pm This is as smooth as it gets:
