I'm declining to answer this right now. I'll have more to say about it later.
The need for a default assembly workbench
- sliptonic
Re: The need for a default assembly workbench
I also use exclusively Asm4 for assemblies; as you said it allows top-down and bottom-up designing, and even combining these within the same project, so it's extremely versatile in this (and other) regards. In addition to your list, I've found that Asm4 has some very unique properties, which I don't think any commercial system has: It's possible (and advisable) to use different solver within the same model. That lead's to great efficiency, because the user has a complete control about where to execute those tedious solver calculations. In the same assembly, one typically has:
- The default LCS solver, i.e. "rigid" solver, which just connects the parts together without possibility of movement. Very typical, and Fast to calculate!
- The Master Sketch solver, where you attach the LCSs to a sketch, which automatically exploits the rather efficient Sketcher plane solver for movements
- The pre-determined movement solver, where you attach an LCS to a pre-determined trajectory in space (a wire + some Python, for example)
- The external solver, which can move your LCSs with any algorithm, for example your own Python program (my experience on these is very limited atm)
Anyways, the fact that you can drop any number of these on your model wherever you need them, is very efficient (fast), versatile, and often quite naturally leads to splitting the assembly problem into smaller interconnected pieces, which I feel is how assembly should be done. So, the Asm4 type of workflow kind of steers one towards the right path when designing an assembly, which is nice.
There are downsides to Asm4 (or any other similar system), of course:
- No reasonable way to add collision detection (this is a big downside)
- There's (currently) no 3D-equivalent space solver of the Sketcher solver in FreeCAD, so the user is limited to combining 2D solvers or writing a problem-specific 3D solver for movements that occur truly in interconnected 3D space with enough degrees-of-freedom. Quite rarely needed, but frustrating problem if it happens...
Here is an excellent page of @jpg87 about assembly DOFs. Hovering or clicking on the images at the bottom even shows small animations. https://help-freecad-jpg87.fr/020_ass_DOF.php
An assembly solver should be able to solve those. Are there more things to consider?
Where?Here is an excellent page of @jpg87 about assembly DOFs.
I think chrisb is refering to https://help-freecad-jpg87.fr/02_ass_ind.php
and specifically https://help-freecad-jpg87.fr/020_ass_outils_contr.php
I have added the link.
Edit: Thanks cadcam.
- sliptonic
Part 4 - assembly 3 deep dive - is live now
Please note that the latest release of A3 is on 2023.01.31
https://github.com/realthunder/FreeCAD_ ... 3/releases relocated to
https://github.com/realthunder/FreeCAD/releases A3 LinkBranch
Instead in your review you wrote:
EDIT:The project is maintained, however its active development phase ended in 2019, and the last workbench release was tagged in 2020.
A3 as WB latest release is on Nov 9, 2022
A3 LinkBranch as sw package release is on 2023.01.31
In the A3 Assy page, it says:
But, of course, ....
This is why I wanted to have a proper Ribbon Bar. It can be shown here: viewtopic.php?t=75791Things don’t get much better with the ModernUI add-on that creates a Ribbon-like top toolbar.
About Nim. Latest Release 2.0.2. Here is Nim in 100 seconds and a Nim package. There are Qt and OCCT packages.
Well, this is confusing. Indeed, package.xml for the WB says the version is 0.11.4 released on 2022-11-09. It was never tagged as a release in git. Let's fix that then, thank you.
Edit: I don't think it makes sense pointing to newer Link releases though. There have been no changes to asm3 code since 0.11.4 release in November.
