[SOLVED] Conda compilations are failing on all platforms (no weekly builds)
https://dev.azure.com/sppedflyer/feedst ... 49ace9e213
error log indicates issue with FEM, somebody has any clues?
2023-03-12T06:44:05.2200166Z [2197/4072] Building CXX object src/Mod/Fem/App/CMakeFiles/Fem.dir/FemMesh.cpp.o
2023-03-12T06:44:05.2200718Z FAILED: src/Mod/Fem/App/CMakeFiles/Fem.dir/FemMesh.cpp.o
2023-03-12T06:44:05.2214123Z $BUILD_PREFIX/bin/x86_64-conda-linux-gnu-c++ -DDIY_NO_THREADS -DFCWithNetgen -DFC_USE_VTK -DFMT_SHARED -DFem_EXPORTS -DH5_BUILT_AS_DYNAMIC_LIB -DHAVE_CONFIG_H -DHAVE_FREEIMAGE -DHAVE_FREETYPE -DHAVE_LIMITS_H -DHAVE_OPENGL_EXT -DHAVE_RAPIDJSON -DHAVE_VTK -DHAVE_XLIB -DNO_PARALLEL_THREADS -DOCCGEOMETRY -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -DQT_XML_LIB -DSALOME_USE_64BIT_IDS -DVTK_OPENGL2_BACKEND -D_OCC64 -Dkiss_fft_scalar=double -I$SRC_DIR/build/src/Mod/Fem/App/Fem_autogen/include -I$SRC_DIR/build -I$PREFIX/include/smesh -I$SRC_DIR/build/src -I$SRC_DIR/src -I$SRC_DIR/build/src/Mod/Fem/App -I$PREFIX/include/opencascade -I$PREFIX/include/python3.10 -isystem $PREFIX/include/qt -isystem $PREFIX/include/qt/QtCore -isystem $PREFIX/./mkspecs/linux-g++ -isystem /opt/conda/include -isystem $PREFIX/include/qt/QtXml -isystem $PREFIX/include/smesh/Driver -isystem $PREFIX/include/smesh/SMESHUtils -isystem $PREFIX/include/smesh/SMDS -isystem $PREFIX/include/smesh/Kernel -isystem $PREFIX/include/vtk-9.1 -isystem $PREFIX/include/smesh/DriverDAT -isystem $PREFIX/include/smesh/DriverGMF -isystem $PREFIX/include/smesh/SMESHDS -isystem $PREFIX/include/smesh/DriverSTL -isystem $PREFIX/include/smesh/DriverUNV -isystem $PREFIX/include/smesh/MEFISTO2 -isystem $PREFIX/include/smesh/Controls -isystem $PREFIX/include/smesh/Geom -isystem $PREFIX/include/smesh/SMESH -isystem $PREFIX/include/smesh/StdMeshers -isystem $PREFIX/include/smesh/NETGENPlugin -isystem $PREFIX/include/smesh/Netgen -isystem $PREFIX/include/smesh/MeshVSLink -isystem $PREFIX/include/freetype2 -Wall -Wextra -Wno-write-strings -fvisibility-inlines-hidden -std=c++17 -fmessage-length=0 -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem $PREFIX/include -fdebug-prefix-map=$SRC_DIR=/usr/local/src/conda/freecad-0.21.pre -fdebug-prefix-map=$PREFIX=/usr/local/src/conda-prefix -Wno-overloaded-virtual -O3 -DNDEBUG -fPIC -Wno-pedantic -fPIC -fopenmp -std=gnu++14 -MD -MT src/Mod/Fem/App/CMakeFiles/Fem.dir/FemMesh.cpp.o -MF src/Mod/Fem/App/CMakeFiles/Fem.dir/FemMesh.cpp.o.d -o src/Mod/Fem/App/CMakeFiles/Fem.dir/FemMesh.cpp.o -c $SRC_DIR/src/Mod/Fem/App/FemMesh.cpp
2023-03-12T06:44:05.2224671Z In file included from $SRC_DIR/src/Base/Observer.h:31,
2023-03-12T06:44:05.2225100Z                  from $SRC_DIR/src/App/Application.h:32,
2023-03-12T06:44:05.2225504Z                  from $SRC_DIR/src/Mod/Fem/App/FemMesh.cpp:63:
2023-03-12T06:44:05.2226413Z $SRC_DIR/src/Base/Console.h: In member function 'constexpr Base::ConsoleSingleton::FreeCAD_ConsoleMsgType Base::ConsoleSingleton::getConsoleMsg(Base::LogStyle)':
2023-03-12T06:44:05.2227341Z $SRC_DIR/src/Base/Console.h:720:15: error: invalid use of template-name 'std::array' without an argument list
2023-03-12T06:44:05.2242845Z   720 |     constexpr std::array msgTypes { // In order of Base::LogStyle
2023-03-12T06:44:05.2283243Z       |               ^~~
2023-03-12T06:44:05.2284225Z $SRC_DIR/src/Base/Console.h:720:15: note: class template argument deduction is only available with '-std=c++17' or '-std=gnu++17'
2023-03-12T06:44:05.2284998Z In file included from $BUILD_PREFIX/x86_64-conda-linux-gnu/include/c++/10.4.0/tuple:39,
2023-03-12T06:44:05.2285644Z                  from $BUILD_PREFIX/x86_64-conda-linux-gnu/include/c++/10.4.0/bits/unique_ptr.h:37,
2023-03-12T06:44:05.2286267Z                  from $BUILD_PREFIX/x86_64-conda-linux-gnu/include/c++/10.4.0/memory:83,
2023-03-12T06:44:05.2286724Z                  from $SRC_DIR/src/Mod/Fem/App/FemMesh.cpp:28:
2023-03-12T06:44:05.2287474Z $BUILD_PREFIX/x86_64-conda-linux-gnu/include/c++/10.4.0/array:94:12: note: 'template<class _Tp, long unsigned int _Nm> struct std::array' declared here
2023-03-12T06:44:05.2288039Z    94 |     struct array
2023-03-12T06:44:05.2288298Z       |            ^~~~~
2023-03-12T06:44:05.2288615Z In file included from $SRC_DIR/src/Base/Observer.h:31,
2023-03-12T06:44:05.2289017Z                  from $SRC_DIR/src/App/Application.h:32,
2023-03-12T06:44:05.2289409Z                  from $SRC_DIR/src/Mod/Fem/App/FemMesh.cpp:63:
2023-03-12T06:44:05.2289958Z $SRC_DIR/src/Base/Console.h:730:12: error: 'msgTypes' was not declared in this scope
2023-03-12T06:44:05.2290469Z   730 |     return msgTypes.at(static_cast<std::size_t>(style));
2023-03-12T06:44:05.2290832Z       |            ^~~~~~~~
2023-03-12T06:44:05.2291123Z ninja: build stopped: subcommand failed.
Re: Conda compilations are failing on all platforms (no weekly builds)
@abdullah I see you touched some stuff about msgTypes in Console.h last week, do you know what could be happening here?
the last line suggest this is an issue with the C++ standard version being used, @looo is the conda build using c++17?
oursland
Post by oursland »
I ran into this while attempting to get a macOS build on M1/M2 Apple Silicon functioning. The issue is that the CMakeLists.txt files for Fem and MeshPart mods set the C++ standard to C++14, as a requirement to build `smesh`. The recently modified code uses the C++17 feature of automated template type deduction, and will not compile in C++14.
I am uncertain if setting the standard to C++14 is still necessary, but in my branch I reverted the commit that introduced these and it built successfully: https://github.com/oursland/FreeCAD/com ... 6d38315049
abdullah
Post by abdullah »
The key part of the error message is this one:
This is expected as deduction guidelines for std::array are only available as from c++17.
The problem is that the minimum supported version for FC is c++17. Somehow your system does not know this.
There are different places where this may be misconfigured (including probably in the IDE).
I have a CMake variable called "BUILD_ENABLE_CXX_STD" with value C++17. I do not know if that helps.
oursland has pointed out that we have code that forces use of c++14 on FEM when using an external SMESH, that seems to be the issue, I have asked now at the commit that introduced this if this is still necessary: git commit 5169a7e852e7
vern.zimm
Post by vern.zimm »
Is this related to viewtopic.php?t=76338 or has this been resolved/they are separate issues?
separate issue but we can't know if the other one is solved until this one is, this is the actual url where I asked werner and looo about this: https://github.com/oursland/FreeCAD/com ... 9f5951c482
now also asked here: https://github.com/trelau/SMESH/issues/40
unfortunately I lack the time to figure out how to set up a conda environment and test building
My version dates of March 4 and has the same revision number as published yesterday. Is it just a problem with the revision number?
OS: macOS 10.16
Version: 0.21.0.32198 (Git)
Hash: f51b2156f35399cab38eef1e957a59ad5a11de66
Python 3.10.9, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: C/Default (C)
  * FC_SU
  * DynamicData 2.46.0
  * freecad.gears 1.0.0
  * FeedsAndSpeeds 0.5.0
  * dxf-library
  * fcgear 1.0.0
  * fasteners 0.4.54
  * sheetmetal 0.2.61
  * ExplodedAssembly
  * Curves 0.6.8
