Chamfer with mill tool
Hello When I start making tool path for this type of object it's just make circles strait down, without compensation to object itself I unable use pocket or profile to get needed result
P.S. testpiece_goal.FCStd it's file that I try to cut
testpiece.FCStd it's what I made to achieve that, but I need create manually new path for each step down, that's why bunch raintagles of different size. For now I have only milling tool for CNC
Endmill tool tip 20mm Diameter
https://drive.google.com/file/d/189u2Ox ... sp=sharing
So here is new file Eye_hole_smoth_Inckscape.FCStd. I used 6 profile to make path for chamfer
Is there any other way make it automatically with pockets or etc? My attempt using pockets are failed, I wish I had tool for that but I must work with what I have for now.
