You have to create a model that looks like that what you want to have. If you have it, make a Job at based of this model -> click at a top face of a stair and use the pocket OP.
Like Gene wrote: The Model has to be a solid...
Chamfer with mill tool
Re: Chamfer with mill tool
Gruß Herbert
I uploaded new file that show what I want with chamfer on milling tool
ModestModest wrote: ↑Tue Mar 14, 2023 12:24 pm OutdatedUPDATECode: Select all
Chamfer with mill tool Hello When I start making tool path for this type of object it's just make circles strait down, without compensation to object itself I unable use pocket or profile to get needed result P.S. testpiece_goal.FCStd it's file that I try to cut testpiece.FCStd it's what I made to achieve that, but I need create manually new path for each step down, that's why bunch raintagles of different size. For now I have only milling tool for CNC
Endmill tool tip 20mm Diameter
https://drive.google.com/file/d/189u2Ox ... sp=sharing
So here is new file Eye_hole_smoth_Inckscape.FCStd. I used 6 profile to make path for chamfer
Is there any other way make it automatically with pockets or etc? My attempt using pockets are failed, I wish I had tool for that but I must work with what I have for now.
For milling the fillets you need Path 3DSurface. It's experimental and you have to enable OCL in the preferences.
There is also a Path Deburr tool, but that works on an edge, where you did not explicitely model the chamfer.
So instead pick face for chamfer creation (in part workbench there was 2 options) I need pick edges of that face ?chrisb wrote: ↑Sat Apr 01, 2023 9:39 am For milling the fillets you need Path 3DSurface. It's experimental and you have to enable OCL in the preferences.
I think so. I didn't use it myself. Did you try it?ModestModest wrote: ↑Mon Apr 03, 2023 5:48 am So instead pick face for chamfer creation (in part workbench there was 2 options) I need pick edges of that face ?
Yeah I tried when build it in both cases I got same model with same issue, as far I understand it just auto select all edges that touch selected Facechrisb wrote: ↑Mon Apr 03, 2023 6:06 amI think so. I didn't use it myself. Did you try it?ModestModest wrote: ↑Mon Apr 03, 2023 5:48 am So instead pick face for chamfer creation (in part workbench there was 2 options) I need pick edges of that face ?
If chamfered in Part workbench, you can leave the model as is, and use the still existing object under the fillet for the Path job.
