Hello, I have my freecad for studies, but I also like to test new appearances, even the @realthunder version. But it's a bit annoying having to backup my configs to be able to test some new interface/config. Searching for this information, I found in the appimage docs that it would work like portable (recording the configs in a local folder), but I tested it here and it didn't work.
"Using portable mode
This page describes a mode some newer AppImages (i.e., built in 2017 or later) provide, the portable mode. This mode allows for bundling an application’s data next to the application’s AppImage."
https://docs.appimage.org/user-guide/portable-mode.html
Portable mod with Appimage on Linux
Re: Portable mod with Appimage on Linux
Hi and welcome to the forum!
Here is a discussion how to do it for FreeCAD: viewtopic.php?f=4&t=49028.
I've read it but haven't tried it yet.
But I still think my suggestion is valid, according to appimage, this is a possibility. If solved it would be much easier than the tutorial shown in this other topic ...
But I know you're full of more important work, here's my request for when I have some time left, thanks for your help and a hug.
- adrianinsaval
what version of the appimage are you using?
It will suffice to make a script in the usb key:
Probably even relative paths will work, so if you place it on an USB key it will work with ./ prefix for the AppImage launcher and the datadir
Note that is copied and is launched using a terminal (in my case urxvt) so your mileage may vary, however the important part is to launch AppImage with the script that set
FREECAD_USER_HOME all the user data will finish here, even addons loade with addonManager
Hope it helps
#!/bin/bash
export FREECAD_USER_HOME="position of the user data directory"
urxvt -T "FreeCAD-launcher" -e "/home/common/FreeCAD/FreeCAD_0.20.2-2022-12-27-conda-Linux-x86_64-py310.AppImage"
Hope it helps
- adrianinsaval
what's the point of using a terminal there? to get warnign/error output there? Normally I think people would want to directly launch the appimage in the script.
I learned the minimum of Shell Script today, lol.
If you are going to use more than one version of freecad appimage, just copy the scripts with different names, the name of the script does not change anything, just its internal content..
Thank you all for your help, hugs..
#!/bin/bash
#Paste the name of your freecad.AppImage here, like this.......
FREECADNAME=FreeCAD_weekly-builds-31917-2023-03-12-conda-Linux-x86_64-py310
mkdir -p $FREECADNAME'_USER_HOME'
export FREECAD_USER_HOME="$FREECADNAME"_USER_HOME""
"./$FREECADNAME.AppImage"
#If you have more portable versions, copy and rename this script.
