File with ProjectionGroup always marked as edited
When loading a file containing a TechDraw page with a ProjectionGroup, the file is diretly after loading marked as changed.
To reproduce:
- Load the attached file.
-> Without any change the file is marked as changed.
OS: macOS 10.16
Version: 0.21.0.32198 (Git)
Hash: f51b2156f35399cab38eef1e957a59ad5a11de66
Python 3.10.9, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: C/Default (C)
  * FC_SU
  * DynamicData 2.46.0
  * freecad.gears 1.0.0
  * FeedsAndSpeeds 0.5.0
  * dxf-library
  * fcgear 1.0.0
  * fasteners 0.4.54
  * sheetmetal 0.2.61
  * ExplodedAssembly
  * Curves 0.6.8
TDLoad.FCStd
(5.43 KiB) Downloaded 22 times
user1234
Re: File with ProjectionGroup always marked as edited
Post by user1234 »
There are more recompute issues atm, but i would not bother as long it works and there is no release atm, since pretty every new addition in TechDraw, this is somehow affected.
Greetings
user1234
user1234 wrote: Tue Mar 14, 2023 8:21 am but i would not bother as long it works
You are right it's not a big issue. I was working on a rather big file, which I have sometimes open for quite some time even while working on other stuff (e.g. looking at forum posts :) ). If I want to track if I have unsaved changes I have to save the file just after reopening. And since I had to do some serious fixes, I would avoid overwriting my automatic backup files one by one.
My solution for now is to set KeepUpdated=false, which does now pretty much what I want.
user1234
Post by user1234 »
Yes, for tracking it is not good atm. The problem is, even when this is fixed, it takes only a few days/weeks, then the issue appears again, since wandererfan is atm working heavy on TechDraw (alone). And as on every work, there are chips falling (which is normal). Just said, a few weeks ago there were some real reloading issues. Now it works much better.
Greetings
user1234
