SliceApart doesn't work?
sanojn
Post by sanojn »
I'm new to FreeCAD and trying to learn.
Version: 0.20.2.29603 (Git)
Branch: releases/FreeCAD-0-20
Locale: Swedish/Sweden (sv_SE)
  * Curves 0.6.8
  * Defeaturing 1.2.0
I have a design with a solid (created from Nurbs surfaces and lofts) that I try to sliceApart
with various compound surfaces. One such surface is a flat plane with a small protrusion
in the center.
The solid is sliced, but remains in a single part, instead of splitting in two separate "exploded"
solids that I intended. I can cut the solid and see the split lines, but the result is considered
a single solid.
When I do the same with a simpler compound surface (two adjoint planes with an angle in between)
it works as I expected, and I get two "exploded" slices that I can transform independently:
In both cases, I'm doing the same operation: Marking the solid, then the compound surface
I want to split with, then: Part WB -> Part -> Split -> Slice Apart.
What am I doing wrong?
The project file is available here. The solid is "Fillet001". The two compund surfaces are Compound (failing) and Compound001 (Working).
Thanks,
Jonas
