Maybe, but that wouldn't reduce the noise.rich61 wrote: ↑Mon Mar 13, 2023 8:50 pm And GeneFC, I guess this function could default to off in the preferences. Since it would use the OS command line, I don't see where it would create so many problems. Any problems are in the OS app, once launched to the OS command line, FC is out of the picture.
Launch Non-FreeCAD Files
Re: Launch Non-FreeCAD Files
I think the strongest objection I hear is that FC isn't a project manager. My argument is that a full project manager isn't required to offer a nice feature, just a list of links.
In the firefox browser I can type "file:///home/rich/FileName.pdf" and Firefox launches the associated PDF app at the OS level, probably on every popular OS, based on the file name and extension.
Another avenue is this:
Using the existing text document in FC, allow links to local disk path, and also internet paths.
I guess it still would have to launch a file open operation at the system level or the system's browser.
Also, the python subprocess function works on all OS that support python.
I think this idea has been fleshed out enough.
Not exactly, you are probably not aware of the fact that each OS has is association system, to launch files.
What is very easy in your description, will work as example if you send your directory to another user that use maybe Linux and you have made you file in Windows or MacOS?
This is why in a multi OS perspective very often scripted solutions are used, when you make the "init part" or the "prepare project dir" target in my example, some magick will happpen to collect informations about OS and presence and location of programs.
Same things as example when making a container like a zipped file, the unzip program will take care of managing differences between OS as there is an intermediate firmat that is OS agnostic.
If you store file paths on FreeCAD your file will be usable only on your machine with the OS that has been used to create the file, except if you use some mechanics to store them in POSIX paths but as example FreeCAD is not yet totally "OS agnostic".
Some users when using multiple files and Links have complained about the fact that some paths should be adapted depending on OS used.
More generally what is easy in your mind has to be translated in code and mechanics that at least in actual development way should be consistent across three OS Linux, Windows and MacOS.
as example in Linux you could even have different shells and you could launch FreeCAD from a shell were the path could even be different from the system one, like when you are executing FreeCAD in a "conda install", so you could be in a situation where FreeCAD could reach system installed software.
Some mechanism to manage projects would be interesting as it is not a strange user case, but probably is not a task for FreeCAD, maybe for an associated project.
I have done the example of Sphinx used to make code documentation, as it is usable from what I remember on the three OS above mentioned plus probably some *BSD variants.
But even in the example it depends on external software, as example to literate some python code I had to install a bunch of Latex packages so it is not a "monkey task".
It is more like when in medieval culinary books some receipt start with "take a deer", some planning has to be made prior to decide what is on the menu today.
Sadly I could not be more aware of different ways as I don't own a MacOS and my Windows user cases are limited. I've used almost exclusively Linux from around 20 years.
Kind Regards
After reading your explanation (thank you!) @onekk I will continue with my simple, homegrown DIY project management scheme
KISS rules
to be honest the only thing I really miss is the ability to add (and keep) comments (verbage) to anything inside the tree?
KISS rules
This will probably more easy to do, or maybe on some extent is already done as some entitites have a Label2 property that probably could be used to place things that will not impact the Treeview.
What could be interesting and probably ease to add, is to have a "note" property that will be able to contain a RichTextEdit text (see Qt explanation) that could be maybe shown as a tooltip (probably adding some Preferences somewhere) so when you hover the treeview you could have these "comments" (say not more than 200 or 300 characters as html markup is using some space).
This way you could maybe add a description, with even maybe an "html link" that could be used to open a page in the "start Page" that from what I remember is managed by a QtWebsomething (Sorry but my memory is not helping).
I don't know how much coding time a similar thing could be done:
@wmayer er @yorik what do you think?
I have seen that the presence of Label2 is not generalized in all FreeCAD "documentObjects" as example "Solid primitives" have not a Label2 property.
EDIT: See below
Something similar could be done with code below that will add a "Notes" category with a "Note" field where you could put a text string, for a "Part WB" Cube named "Box":
obj = FreeCAD.getDocument('Unnamed').getObject('Box')
obj.addProperty("App::PropertyString", "Notes", "Notes", "Note")
obj.Notes = "New Note"
yes, and I use it a lot (where appropriate)
I had in mind more verbose "comments" on design intent behind the way something is done/designed,
so that when I come back to the project after a while, I can read rather than have to guess
I have added text documents as well, and this is close to what I have in mind
@onekk
I like your idea of note property
Rich text would make my day
Is this true?
Have you selected the object in the tree, gone to the Properties view, right click and select "Show all".
- Screenshot_20230314_080834.png (63.26 KiB) Viewed 569 times
No I haven't done this, amended above post, nice to know.
Sorry but I'm not a GUI user, I prefer to make thing using scripts, so.
