Line command
paulye
Line command
Post by paulye »
Dear friends,
I am new to FreeCad.
Try to draw a line, but only two points appeared on the workbench, the solid line appears only when cursor moves over it.
Please kindly advise to resolve this issue.
Thank you.
Paul Yap
jfc4120
Re: Line command
Post by jfc4120 »
Show version. viewtopic.php?t=2264
edwilliams16
Re: Line command
Post by edwilliams16 »
paulye wrote: Sun Mar 12, 2023 2:44 pm
There's many ways to create a line. What workbench? Part? Sketcher? Draft? Please explain in more detail exactly what you are doing.
Re: Line command
This sounds to me like a graphics card issue. Some are mentioned in the Known OS specific issues, and you can always upgrade the driver.
paulye
Re: Line command
Post by paulye »
edwilliams16 wrote: Mon Mar 13, 2023 1:49 am
Thanks for your input.
Just downloaded the latest version of FreeCad 0.20 and also watched some demonstration from Youtube. Very exited to start to learn FreeCad.
I was using Sketcher workbench. I tried to use line command to draw a line but only 2 points appeared on the workbench, I also tried other commands, results are the same, solid line appears only when cursor moves over it.
Without solving this issue, I'm not able to proceed further.
Please kindly advise.
Thank you.
Paukye
Shalmeneser
Re: Line command
Post by Shalmeneser »
Can you provide your full version infos (follow link in red banner) ?
Can you provide a picture screen copy at critical moment ?
jfc4120
Re: Line command
Post by jfc4120 »
I myself really want to help but it's no good description.
I draw lines all the time and never have such problems, so provide a detailed exact description of how you are doing the line, as said above include some screenshots.
You can attach files.
heda
Re: Line command
Post by heda »
sketch in edit
Snip macro screenshot-55711c.png (6.71 KiB) Viewed 436 times
sketch out of edit
Snip macro screenshot-c578f0.png (1.44 KiB) Viewed 436 times
open file on yourbox, if it looks different on your box, explain what is different...
sketchwline.FCStd
(3.8 KiB) Downloaded 8 times
paulye
Re: Line command
Post by paulye »
Shalmeneser wrote: Mon Mar 13, 2023 9:24 am Can you provide your full version infos (follow link in red banner) ?
FreeCad sketcher.PNG (172.45 KiB) Viewed 363 times
Thanks for your help.
Screenshot of the Freecad page is attached.
Hopefully my info is helpful.
Thank you.
Paulye
Bance
Re: Line command
Post by Bance »
White lines on a white background? are you a troll? :lol: :lol: :lol:
