I'm encountering an error as below when attempting to run pylint on a very simple and reproducible FreeCAD script file. I want to understand the cause and find workarounds.
$ pylint pylint_test.py
Segmentation fault (core dumped)
I'm updating some scripts I wrote in the past to include some restrictive CI pipeline checks for merging. I ran into an issue that doesn't appear during normal execution/testing with pytest but only when running pylint on a small reproducible example as below. I'm honestly not sure about the inner workings of pylint and so wanted to see if this is an understood problem in FreeCAD or not first.
Python file to reproduce:
import FreeCAD
import Part
circ = Part.makeCircle(1, FreeCAD.Vector(0, 0, 0), FreeCAD.Vector(0, 0, 1), 0, 360)
circ.Placement = FreeCAD.Placement()
pylint file_from_above.py
OS: Linux Mint 20.2 (X-Cinnamon/cinnamon)
Version: 0.20.1.
Branch: unknown
Hash: 1397818c9664d158281339a84be59d3e9887f6ad
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.2
