For some reason, cmake is pulling OCCT stuff out of PrusaSlicer, rather than out of my installed libraries. This is alpha sw and in it's own directory, with it's own occt libs. How do I get cmake to stop pulling stuff out of a "private alpha test sandbox" area?
/Apps/freecad-build$ cmake .
-- Compiler: GNU, version: 11.3.0
-- prefix: /usr/local
-- bindir: bin
-- datadir: share
-- docdir: share/doc/FreeCAD
-- includedir: include
-- libdir: lib
-- cmake: 3.22.1
-- Compiling with Qt 5
-- Checking for connection to GitHub...
-- GitHub connection established for FetchContent
-- Module support is disabled.
-- Version: 9.1.0
-- Build type: Release
-- CXX_STANDARD: 17
-- Required features: cxx_variadic_templates
-- fmt was downloaded using FetchContent into /home/bruce/Apps/freecad-build/_deps/fmt-src
-- PyCXX found:
-- Headers: /home/bruce/Apps/freecad-source/src
-- Sources: /home/bruce/Apps/freecad-source/src/CXX
-- Version: 7.1.7
CMake Error at /home/bruce/Apps/PrusaSlicer/deps/build/dep_OCCT-prefix/src/dep_OCCT-build/OpenCASCADEConfig.cmake:95 (include):
include could not find requested file:
/home/bruce/Apps/PrusaSlicer/deps/build/dep_OCCT-prefix/src/dep_OCCT-build/OpenCASCADEFoundationClassesTargets.cmake
Call Stack (most recent call first):
cMake/FindOCC.cmake:39 (find_package)
cMake/FreeCAD_Helpers/SetupOpenCasCade.cmake:4 (find_package)
CMakeLists.txt:53 (SetupOpenCasCade)
/home/bruce/Apps/PrusaSlicer/deps/build/dep_OCCT-prefix/src/dep_OCCT-build/OpenCASCADEModelingDataTargets.cmake
/home/bruce/Apps/PrusaSlicer/deps/build/dep_OCCT-prefix/src/dep_OCCT-build/OpenCASCADEModelingAlgorithmsTargets.cmake
/home/bruce/Apps/PrusaSlicer/deps/build/dep_OCCT-prefix/src/dep_OCCT-build/OpenCASCADEVisualizationTargets.cmake
/home/bruce/Apps/PrusaSlicer/deps/build/dep_OCCT-prefix/src/dep_OCCT-build/OpenCASCADEApplicationFrameworkTargets.cmake
/home/bruce/Apps/PrusaSlicer/deps/build/dep_OCCT-prefix/src/dep_OCCT-build/OpenCASCADEDataExchangeTargets.cmake
CMake Error at cMake/FindOCC.cmake:101 (file):
file STRINGS file
"/home/bruce/Apps/PrusaSlicer/deps/build/dep_OCCT-prefix/src/include/opencascade/Standard_Version.hxx"
cannot be read.
CMake Error at cMake/FindOCC.cmake:104 (string):
string sub-command REGEX, mode MATCH needs at least 5 arguments total to
command.
CMake Error at cMake/FindOCC.cmake:105 (file):
file STRINGS file
cannot be read.
CMake Error at cMake/FindOCC.cmake:108 (string):
command.
CMake Error at cMake/FindOCC.cmake:109 (file):
file STRINGS file
cannot be read.
CMake Error at cMake/FindOCC.cmake:112 (string):
command.
-- -- Found OCE/OpenCASCADE version: ..
-- -- OCE/OpenCASCADE include directory: /home/bruce/Apps/PrusaSlicer/deps/build/dep_OCCT-prefix/src/include/opencascade
-- -- OCE/OpenCASCADE shared libraries directory: /home/bruce/Apps/PrusaSlicer/deps/build/dep_OCCT-prefix/src/lib
-- The imported target "vtkParseOGLExt" references the file
"/usr/bin/vtkParseOGLExt-7.1"
but this file does not exist. Possible reasons include:
* The file was deleted, renamed, or moved to another location.
* An install or uninstall procedure did not complete successfully.
* The installation package was faulty and contained
"/usr/lib/cmake/vtk-7.1/VTKTargets.cmake"
but not all the files it references.
-- The imported target "vtkRenderingPythonTkWidgets" references the file
"/usr/lib/x86_64-linux-gnu/libvtkRenderingPythonTkWidgets.so"
-- The imported target "vtk" references the file
"/usr/bin/vtk"
-- The imported target "pvtk" references the file
"/usr/bin/pvtk"
-- VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkIOMPIParallel;vtkParallelMPI;vtkhdf5;vtkFiltersParallelDIY2;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2
-- Check for medfile (libmed and libmedc) ...
-- We guess that libmed was built using hdf5-openmpi version
-- Found Boost: /usr/lib/x86_64-linux-gnu/cmake/Boost-1.74.0/BoostConfig.cmake (found suitable version "1.74.0", minimum required is "1.65") found components: filesystem program_options regex system thread date_time
-- Set up to compile with Qt 5.15.3
-- Shiboken2Config: Using default python: .cpython-310-x86_64-linux-gnu
-- SHIBOKEN_PYTHON_INCLUDE_DIRS computed to value: '/usr/include/python3.10'
-- SHIBOKEN_PYTHON_LIBRARIES computed to value: ''
-- libshiboken built for RelWithDebInfo
-- PYTHON_CONFIG_SUFFIX: .cpython-310-x86_64-linux-gnu
-- PySide 5.15.2 Python module found at /usr/lib/python3/dist-packages/PySide2.
-- Found Matplotlib: /usr/lib/python3/dist-packages/matplotlib (found version "3.5.1")
-- Platform is 64-bit, set -D_OCC64
-- Performing Test _flag_found
-- Performing Test _flag_found - Success
-- [E57] Revison ID: E57Format-2.2.1-x86_64-linux-gcc11
-- [E57] Building static library
-- setting gcc options: -Wall -Werror -Wno-deprecated -pedantic-errors
-- Found Boost: /usr/lib/x86_64-linux-gnu/cmake/Boost-1.74.0/BoostConfig.cmake (found version "1.74.0") found components: python310
-- found Boost: 1_74
-- boost-incude dirs are: /usr/include
-- boost-python lib is:
-- boost_LIBRARY_DIRS is: /usr/lib/x86_64-linux-gnu
-- Boost_LIBRARIES is: Boost::python
-- area module (for Path Workbench) will be installed to: lib
<string>:1: DeprecationWarning: The distutils package is deprecated and slated for removal in Python 3.12. Use setuptools or check PEP 632 for potential alternatives
<string>:1: DeprecationWarning: The distutils.sysconfig module is deprecated, use sysconfig instead
-- Coin3D doc is not installed
System
-- bindir: bin
-- BLAS: -undefined-
-- CMAKE_VERSION: 3.22.1
-- Compiler: /usr/bin/c++ (11.3.0)
-- datadir: share
-- libdir: lib
-- Python: 3.10.6 [/usr/bin/python3.10] Suffix: [.cpython-310-x86_64-linux-gnu]
Config
-- BUILD_FEM: ON
-- BUILD_GUI: ON
-- BUILD_SMESH: ON
-- BUILD_START: ON
-- BUILD_TECHDRAW: ON
-- BUILD_TEST: ON
-- BUILD_VR: OFF
-- BUILD_WEB: ON
-- CMAKE_BUILD_TYPE: Release
-- CMAKE_CXX_FLAGS: -Wall -Wextra -Wno-write-strings
-- CMAKE_CXX_STANDARD: 17
-- CMAKE_INSTALL_PREFIX: /usr/local
-- CMAKE_PREFIX_PATH: -undefined-
-- FREECAD_CREATE_MAC_APP: -undefined-
-- FREECAD_LIBPACK_USE: OFF
-- FREECAD_QT_VERSION: Auto
-- FREECAD_USE_EXTERNAL_KDL: OFF
-- FREECAD_USE_EXTERNAL_SMESH: OFF
-- FREECAD_USE_FREETYPE: ON
-- FREECAD_USE_PYBIND11: OFF
-- PYTHON_EXECUTABLE: /usr/bin/python3.10
-- PYTHON_LIBRARY: /usr/lib/x86_64-linux-gnu/libpython3.10.so
-- USE_CUDA: -undefined-
-- USE_OPENCV: -undefined-
Libraries
-- Boost: 1.74.0
-- Coin3D: 4.0.0 [/usr/lib/x86_64-linux-gnu/libCoin.so] [/usr/include]
-- Coin3D_DOC: not found
-- DesignerPlugin: not built (BUILD_DESIGNER_PLUGIN is OFF)
-- Doxygen: 1.9.1 Language: English
-- Eigen3: 3.4.0
-- fmt: Sources downloaded to /home/bruce/Apps/freecad-build/_deps/fmt-src
-- Freetype: 2.11.1
-- HDF5: 1.10.7
-- Matplotlib: 3.5.1 PathDirs: /usr/lib/python3/dist-packages/matplotlib
-- MEDFile: 4.1.0 [/usr/lib/x86_64-linux-gnu/libmedC.so] [/usr/include]
-- NETGEN: not enabled
-- OCC: .. [/home/bruce/Apps/PrusaSlicer/deps/build/dep_OCCT-prefix/src/lib] [/home/bruce/Apps/PrusaSlicer/deps/build/dep_OCCT-prefix/src/include/opencascade]
-- OCC_Libs: [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBool;TKBO;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEPBase;TKSTEPAttr;TKSTEP209;TKSTEP;TKHLR;TKFeat]
-- OpenGL_Lib: [/usr/lib/x86_64-linux-gnu/libGL.so]
-- OpenGLU_Incl: [/usr/include]
-- OpenGLU_Lib: [/usr/lib/x86_64-linux-gnu/libGLU.so]
-- pivy: 0.6.5
-- pybind11: not enabled
-- PYCXX: 7.1.7 Incl: /home/bruce/Apps/freecad-source/src Src:/home/bruce/Apps/freecad-source/src/CXX
-- PySide: 5.15.2 [/usr/lib/../include/PySide2]
-- PySideTools: v: 2 uic: [/usr/lib/qt5/bin/uic] rcc: [/usr/lib/qt5/bin/rcc]
-- QtConcurrent: 5.15.3
-- QtCore: 5.15.3
-- QtNetwork: 5.15.3
-- QtOpenGL: 5.15.3
-- QtPrintSupport: 5.15.3
-- QtSvg: 5.15.3
-- QtUiTools: 5.15.3
-- QtWebEngineWidgets: 5.15.9
-- QtWidgets: 5.15.3
-- QtXml: 5.15.3
-- Rift: not enabled (BUILD_VR)
-- Shiboken: 5.15.2 [/usr/lib/../include/shiboken2;/usr/include/python3.10]
-- SMESH: 7.7.1.0 build internal
-- SPNAV: [/usr/lib/libspnav.so] [/usr/include]
-- SWIG: 4.0.2
-- VTK: 7.1.1
-- XercesC: 3.2.3 [/usr/lib/x86_64-linux-gnu/libxerces-c.so] [/usr/include]
-- ZLIB: 1.2.11
Now run 'cmake --build /home/xxx/Apps/freecad-build' to build FreeCAD
-- Configuring incomplete, errors occurred!
See also "/home/xxx/Apps/freecad-build/CMakeFiles/CMakeOutput.log".
