Jupyter ❤️ FreeCAD
Re: Jupyter ❤️ FreeCAD
Regarding the openscad support, this is not what we have in mind. The current grant should allow us to streamline this demonstrator.
We would really like to engage with folks on the FreeCAD developer community (as it is the first file format that we decided to support) also to identify potential next steps and collaborations.
Next month we will be having our first (virtual) all-developer meetup -- maybe you could join us? It's going to be on the first Sunday of May at 19h00 CET.
@SylvainCorlay thanks for this great initiative. I tried it out and managed to open the CAD "tab" in JupyterLab, and new drawings are possible. However, any models that I load are not rendered. Could you help me out with figuring out what may be going on?
So far this is what I have:
JupyterLab 4.0.0b2
jupytercad (through pip)
freecad 0.20.2 (through snap)
JupyterLab 4.0.0b2
Thanks for trying it out, we're working on supporting jupyterlab 4 beta, currently, it only works with jupyterlab 4.0.0a32.jnxd wrote: ↑Mon Apr 03, 2023 4:55 am @SylvainCorlay thanks for this great initiative. I tried it out and managed to open the CAD "tab" in JupyterLab, and new drawings are possible. However, any models that I load are not rendered. Could you help me out with figuring out what may be going on?
JupyterLab 4.0.0b2
FYI, JupyterCAD 0.1 was released last week, following the final release of JupyterLab 4.0.
I have a similar issue, trying to open the "example1.FCStd", nothing is displayedtrungleduc wrote: ↑Tue Apr 04, 2023 8:28 amThanks for trying it out, we're working on supporting jupyterlab 4 beta, currently, it only works with jupyterlab 4.0.0a32.jnxd wrote: ↑Mon Apr 03, 2023 4:55 am @SylvainCorlay thanks for this great initiative. I tried it out and managed to open the CAD "tab" in JupyterLab, and new drawings are possible. However, any models that I load are not rendered. Could you help me out with figuring out what may be going on?
JupyterLab 4.0.0b2
FREECADPATH = "/usr/lib64/freecad/lib64"
import sys
sys.path.append(FREECADPATH)
import FreeCAD as freecad
from jupytercad import CadDocument
doc = CadDocument('example1.FCStd')
display(doc)
[I 2023-06-03 17:36:06.801 ServerApp] Request for Y document '/home/adi/freecad-projekty/example1.FCStd' with room ID: 6fe6d683-e706-41f7-a97a-8a8a9b243945
[I 2023-06-03 17:36:06.813 YDocExtension] Creating FileLoader for: freecad-projekty/example1.FCStd
[I 2023-06-03 17:36:06.814 YDocExtension] Watching file: freecad-projekty/example1.FCStd
[I 2023-06-03 17:36:06.816 ServerApp] Initializing room base64:FCStd:6fe6d683-e706-41f7-a97a-8a8a9b243945
[I 2023-06-03 17:36:06.822 ServerApp] Content in room base64:FCStd:6fe6d683-e706-41f7-a97a-8a8a9b243945 loaded from file freecad-projekty/example1.FCStd
jupytercad-extension 0.2.0-alpha.0
OS: Fedora Linux 37 (KDE Plasma) (KDE/plasma)
Version: 0.21.0.pre_33348.fc37 (Git)
Build type: Unknown
Python 3.11.3, Qt 5.15.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: Polish/Poland (pl_PL)
* freecad.gears 1.0.0
Hi, could you upgrade to JupyterCAD 0.2.3? The alpha version does not work with JupyterLab 4.xkwahoo wrote: ↑Sat Jun 03, 2023 3:44 pmI have a similar issue, trying to open the "example1.FCStd", nothing is displayedtrungleduc wrote: ↑Tue Apr 04, 2023 8:28 amThanks for trying it out, we're working on supporting jupyterlab 4 beta, currently, it only works with jupyterlab 4.0.0a32.jnxd wrote: ↑Mon Apr 03, 2023 4:55 am @SylvainCorlay thanks for this great initiative. I tried it out and managed to open the CAD "tab" in JupyterLab, and new drawings are possible. However, any models that I load are not rendered. Could you help me out with figuring out what may be going on?
JupyterLab 4.0.0b2
freecad 0.20.2 (through snap)Console output:Code: Select all
FREECADPATH = "/usr/lib64/freecad/lib64" import sys sys.path.append(FREECADPATH) import FreeCAD as freecad from jupytercad import CadDocument doc = CadDocument('example1.FCStd') display(doc)
JupiterLab 4.0.1Code: Select all
[I 2023-06-03 17:36:06.801 ServerApp] Request for Y document '/home/adi/freecad-projekty/example1.FCStd' with room ID: 6fe6d683-e706-41f7-a97a-8a8a9b243945 [I 2023-06-03 17:36:06.813 YDocExtension] Creating FileLoader for: freecad-projekty/example1.FCStd [I 2023-06-03 17:36:06.814 YDocExtension] Watching file: freecad-projekty/example1.FCStd [I 2023-06-03 17:36:06.816 ServerApp] Initializing room base64:FCStd:6fe6d683-e706-41f7-a97a-8a8a9b243945 [I 2023-06-03 17:36:06.822 ServerApp] Content in room base64:FCStd:6fe6d683-e706-41f7-a97a-8a8a9b243945 loaded from file freecad-projekty/example1.FCStd
jupytercad-extension 0.2.0-alpha.0Code: Select all
OS: Fedora Linux 37 (KDE Plasma) (KDE/plasma) Word size of FreeCAD: 64-bit Version: 0.21.0.pre_33348.fc37 (Git) Build type: Unknown Python 3.11.3, Qt 5.15.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3 Locale: Polish/Poland (pl_PL) Installed mods: * freecad.gears 1.0.0
Thank you for your reply! Unfortunately, no luck. Tried both JupyterCAD 0.2.3 and JupiterLab extension. I can create a JCAD with new solids, but cannot open a FreeCAD file.trungleduc wrote: ↑Mon Jun 05, 2023 2:21 pm
Could you open an issue here https://github.com/QuantStack/jupytercad/issues with more detail about your Python environment? Since you can work with a JCAD file, the issue may be related to importing FreeCADkwahoo wrote: ↑Mon Jun 05, 2023 3:35 pmThank you for your reply! Unfortunately, no luck. Tried both JupyterCAD 0.2.3 and JupiterLab extension. I can create a JCAD with new solids, but cannot open a FreeCAD file.trungleduc wrote: ↑Mon Jun 05, 2023 2:21 pm
