I noticed that the TechDraw Detail View circle cropping does not work any more with the newest TD version, so I think there is a regression with this functionality. The Detail View is supposed to draw a circle around the Detail View and crop everything outside the perimeter of this circle, however in the current version this doesn't seem to work correctly and it's even possible to add a Dimension to the geometry that is supposed to be cropped away (see the attached picture). This is a minor cosmetic inconvenience and it probably should not be high priority, but I wanted to bring this into attention anyway, so that the bug won't be forgotten. Thanks!
EDIT: Could this be caused by the (quite) recent change in the stack ordering of TD objects that fixed another problem with object visibility on pages?
Version: 0.21.0.32198 (Git)
Hash: f51b2156f35399cab38eef1e957a59ad5a11de66
Python 3.8.16, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
* Assembly4 0.12.4
* Curves 0.5.8
* Defeaturing 1.2.0
* fasteners 0.4.6
* FCGear 1.0.0
* freecad.gears 1.0.0
* Manipulator 1.4.9
* Reinforcement
* Render 2022.2.0
* sheetmetal 0.2.57
* ThreadProfile 1.83.0
* toSketch 1.0.0
