Path Profile on selected face fails
RaccoonBuilds
Post by RaccoonBuilds »
I'm trying to create a corner jig for my cnc. I already have cut the shape and I now want to do a second operation. I would like to do a profile operation on the inside corner faces. I have them shown in the attached image.
I keep getting an error though.
16:07:52  <Path.Area> Area.cpp(1437): hit bottom -0,0,1e-06
16:07:52  <Path.Area> Area.cpp(1317): project failed
16:07:52  <Path.Area> Area.cpp(1619): skipped 1 sub shapes during projection
16:07:52  <Path.Area> Area.cpp(1459): empty projection
16:07:52  PathProfile.ERROR: Unable to create path for face(s).
list index out of range
Corner_jig.FCStd
(48.68 KiB) Downloaded 22 times
Selected Faces
Selected Faces
Screenshot from 2023-03-08 16-11-10.png (48.63 KiB) Viewed 1152 times
GeneFC
Re: Path Profile on selected face fails
Post by GeneFC »
RaccoonBuilds wrote: Thu Mar 09, 2023 12:22 am
I will guess you want to create something like this.
If so, I would suggest you select the top edges instead of the faces. Also, it is necessary to select the desired final depth. It appears that the automatic selection is not correct.
If this does not answer your question please add a bit more detail about what you want.
Gene
RaccoonBuilds
Thanks Gene! That is exactly what I was looking to do.
GeneFC wrote: Thu Mar 09, 2023 12:36 am If so, I would suggest you select the top edges instead of the faces. Also, it is necessary to select the desired final depth. It appears that the automatic selection is not correct.
I was not able to select only these inner edges for a profile operation, although I found the placement of the stock very smart.
But I managed to get the correct depth, when selecting the bottom edges instead of the top. Maybe we can join our efforts and get a path for the right edges and the right depths :mrgreen: .
Until then I would use a boundary dressup to exclude the outer edges.
GeneFC
Post by GeneFC »
chrisb wrote: Thu Mar 09, 2023 12:00 pm
Selecting the top edges or the bottom edges works, but selecting the top will require checking the final depth. I always need to set the final depth and the stepdown, since the automatic entries never work for me.
I forgot to mention that I moved the stock as well. Simply used the "Refresh" on the Job setup tab. I do this routinely all the time, so it is automatic for me.
It does not matter in this case. (I just rechecked)
Gene
GeneFC wrote: Thu Mar 09, 2023 1:24 pm It does not matter in this case. (I just rechecked)
So how did you arrive at only the inner paths being created in your post above? Would you mind uploading the file for further studies?
GeneFC
Post by GeneFC »
chrisb wrote: Thu Mar 09, 2023 1:30 pm So how did you arrive at only the inner paths being created in your post above? Would you mind uploading the file for further studies?
It is possible I am not understanding, because this seems very easy. In the Profile operation I just deleted the faces that the OP had selected and added the three top edges. I set an arbitrary final depth and came up with the path I showed above.
Corner_jig-GFC.FCStd
(50.26 KiB) Downloaded 12 times
This was done with 0.21.30454, which was just before the great refactor. Otherwise I would have needed to either fix the FCStd file or delete the Job and start again.
Gene
GeneFC wrote: Thu Mar 09, 2023 2:14 pm This was done with 0.21.30454, which was just before the great refactor. Otherwise I would have needed to either fix the FCStd file or delete the Job and start again.
Thanks. I will dig a bit deeper. I still have 30430 and 30492 around. I will report back.
So this is solved. In current 0.21 I can select the edges and get the paths only for them.
But a new issue occurred. I have treated your last file
GeneFC wrote: Thu Mar 09, 2023 2:14 pm Corner_jig-GFC.FCStd
(50.26 KiB) Downloaded 3 times
with the migration script JobFixer.py from sliptonic. When I load it, the job looks good, but I get an error when I doubleclick on the Profile operation:
20:07:44  Traceback (most recent call last):
  File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/Mod/Path/Path/Op/Gui/Base.py", line 103, in setEdit
    page = self.getTaskPanelOpPage(vobj.Object)
  File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/Mod/Path/Path/Op/Gui/Base.py", line 166, in getTaskPanelOpPage
    mod = importlib.import_module(self.OpPageModule)
  File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/lib/python3.10/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1004, in _find_and_load_unlocked
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathProfileGui'
20:07:46  Traceback (most recent call last):
20:07:52  Traceback (most recent call last):
20:08:45  Traceback (most recent call last):
I attach the converted file.
CornerjigFixed.fcstd
(224.5 KiB) Downloaded 14 times
GeneFC
Post by GeneFC »
chrisb wrote: Thu Mar 09, 2023 7:15 pm
I get the same "frozen" errors when I open the Profile.
No clue. I have never seen anything like that.
Gene
