Running v 20.1 on a mac.
Trying to design a house (to learn).
Can't seem to get a window added properly.
Here's what I thought was correct:
1) in Draft, draw a line
2) in Arch, make it a wall
3) change the working plane to the wall surface
4) click Window icon
5) select type of window and use snaps to place on wall
Whatever I do, I get errors:
10:53:00 Choose a face on an existing object or select a preset
10:53:07 Traceback (most recent call last):
File "/Applications/FreeCAD.app/Contents/Resources/Mod/Arch/ArchWindow.py", line 889, in execute
shapes = self.buildShapes(obj)
File "/Applications/FreeCAD.app/Contents/Resources/Mod/Arch/ArchWindow.py", line 687, in buildShapes
wires.append(obj.Base.Shape.Wires[j])
<class 'IndexError'>: list index out of range
10:53:07 Recompute failed! Please check report view.
Any ideas what I'm doing wrong?
Thanks!
New To Arch
Re: New To Arch
Moved from Help forum.
Re: New To Arch
I can't reproduce. Please upgrade to V0.20.2 and test again. If that does not help: post your file.
Locale: English/United States (en_US) [ OS: Dutch/Netherlands (nl_NL) ]
Version: 0.21.0.32198 (Git)
Hash: f51b2156f35399cab38eef1e957a59ad5a11de66
Python 3.8.16, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Re: New To Arch
Updated to latest version. No help.
Red error says "List index out of range".
Can't figure out what I'm doing wrong.
Any help would be appreciated.
- Window.FCStd
- (21.15 KiB) Downloaded 33 times
Re: New To Arch
There is something wrong with the sketch your window is based on. The standard "Open 2-pane" window is based on a sketch with 24 lines. Between the 8 lines that define the fixed frame and the 8 lines that define each of the two window frames there is a gap. In your file this gap is missing resulting in superimposed lines. This confuses the algorithm that looks for closed loops in the sketch. Can you specify which inputs (Width, Height, H1, H2, etc.) you have used?
Re: New To Arch
That's it!
Thank you so much!
Edit the parameters prior to placement, and all good.
It's going to take some getting used to committing to a set value, because, it doesn't seem that I can change type of window once placed, but at least I have WINDOWS!
Thank you.
Thank you so much!
Thank you.
