I have modeled a rotor installed in a box and meshing fails when I introduce refinements to the model. Model file and snapshot of the error message are attached.
Can someone review the setup and let me know what the problem might be. I can generate mesh with refinements, successfully.
Using FreeCAD version 0.20.2 installed on Windows 10
Thanks
Freecad CFDoF Meshing fails With refinement(s)
Moderator: oliveroxtoby
- WT.FCStd
- (394.6 KiB) Downloaded 43 times
- Error.PNG (8.59 KiB) Viewed 906 times
Re: Frrecad CFDoF Meshing fails With refinement(s)
Meshing works here, also refinement, but i'm missing the bounderys...
Gruß Herbert
Herbert,
Interesting! What version of FreeCAD and gmsh are you using?
- Raedchen_im_System
@hooshsim : I can mesh your FreeCad-model on my computer as well. My current configuration:
Could it be that you are having problems with your cfMesh installation? You can check the dependency checker in edit => settings:
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
* A2plus
* Assembly4 0.12.5
* CfdOF 1.21.4
* fasteners
* FCGear
* Plot
- oliveroxtoby
As @Raedchen_im_System says, this happens because the CfdOF version of cfMesh is not installed. If you run the dependency checker, it should tell you that. Installing cfMesh from the preferences panel should fix the issue.hooshsim wrote: ↑Tue Mar 07, 2023 8:08 pm I have modeled a rotor installed in a box and meshing fails when I introduce refinements to the model. Model file and snapshot of the error message are attached.
Thanks
Re: Freecad CFDoF Meshing fails With refinement(s)
Reinstalling cfmesh fixed the problem. Thanks to all. Advancing to the next level. Love cfdof!
