Good day.
Try to get more compact toolbar.
Is it possible to change name or replace with icon?
[implemented] Add icon or change name for tooltip
Re: Add icon or change name for tooltip
I see what you mean, and I'm sorry that I can't help, but did you consider to use the keyboard shortcuts? Since I discovered them I don't use the toolbar at all - which results in even more space.
I've submitted a Pull Request https://github.com/FreeCAD/FreeCAD/pull/8793 but this is subject to approval and not every command has to have an icon but in this case I believe it's a good case as we have one for Recent Files, therefore Recent Macros isn't out of order IMHO.
This has been merged and therefore will be available in the next Weekly 0.21dev build probably this Sunday afternoon.
- adrianinsaval
Re: [implemented] Add icon or change name for tooltip
unfortunately the weekly builds are not working right now: https://github.com/looooo/freecad-feeds ... 1872717414
looo has corrected something, but it seem that something is failing during compilation:adrianinsaval wrote: ↑Thu Mar 09, 2023 2:43 pm unfortunately the weekly builds are not working right now: https://github.com/looooo/freecad-feeds ... 1872717414
https://dev.azure.com/sppedflyer/feedst ... 2e683d1642
In file included from $SRC_DIR/src/Mod/Fem/App/FemMeshShapeNetgenObject.cpp:38:
2023-03-09T06:47:32.8834215Z $SRC_DIR/src/Base/Console.h:730:12: error: 'msgTypes' was not declared in this scope
2023-03-09T06:47:32.8834681Z 730 | return msgTypes.at(static_cast<std::size_t>(style));
2023-03-09T06:47:32.8835032Z | ^~~~~~~~
2023-03-09T06:47:35.1090713Z [2194/4065] Building CXX object src/Mod/Fem/App/CMakeFiles/Fem.dir/FemAnalysis.cpp.o
2023-03-09T06:47:40.8712439Z [2195/4065] Building CXX object src/Mod/Fem/App/CMakeFiles/Fem.dir/FemMesh.cpp.o
2023-03-09T06:47:40.8713533Z FAILED: src/Mod/Fem/App/CMakeFiles/Fem.dir/FemMesh.cpp.o
subprocess.CalledProcessError: Command '['/bin/bash', '-o', 'errexit', '/home/conda/feedstock_root/build_artifacts/freecad_1678343056159/work/conda_build.sh']' returned non-zero exit status 1.
##[error]Bash exited with code '1'.
Finishing: Run docker build
As example for OSX.
2023-03-09T07:06:06.4453970Z FAILED: src/Mod/Fem/App/CMakeFiles/Fem.dir/FemMeshShapeNetgenObject.cpp.o
But I can't be so precise as I'm not a C++ expert.
