[Solved] Amount of used computing cores ?
Moderator: oliveroxtoby
herbk
Post by herbk »
after a longer time not using CfdOF i stumbled about a few things, - mostly UI releatet, - and that the solver only works with one Core...
Didn't it work with cores in parallel before ?
Edit:
It took me a few days, but i get succes now.
openSuse (i think other linux distros to) clening up the repos and moving pakages...
At a fresh installation of openSuse Tumbleweed i took this steps to get CfdOF with full multicore calculation running:
Needed steps to get CfdOF WB working (OpenSuse Tumbleweed)
This pakages have to be installed ( status 14.03.2023 ) :
gmsh
zlib-devel
openfoam2206		(or earlyer)
openmpi1
openmpi1-devel
python3-paraview
With OpenFoam and OpenMPI OpenSuse installs a Selector which needs to be configured.
For the type this comands at a terminal ( no root permission needed )
Für OpenFoam:
openfoam-selector-menu
select the version to use
Für OpenMPI
mpi-selector-menu
select openmpi1
Restart the computer !
If this is done, it’s possible to install cfMesh and Hisa
Both need a few minutes.
Installationshinweise.pdf
(15.4 KiB) Downloaded 67 times
Gruß Herbert
NewJoker
Re: Amount of used computing cores ?
Post by NewJoker »
Is Parallel set to true and Parallel Cores set to the desired number of cores in your CfdSolver settings ?
herbk
Post by herbk »
NewJoker wrote: Tue Mar 07, 2023 9:34 am Is Parallel set to true and Parallel Cores set to the desired number of cores in your CfdSolver settings ?
If o do so, i got
 Simulation exited with error
and the Report view shows
Decomposing mesh
Create mesh
14:08:25
Calculating distribution of cells
Decomposition method scotch [4] (region region0)
14:08:25
Finished decomposition in 0.05 s
Calculating original mesh data
Distributing cells to processors
14:08:25
Distributing faces to processors
Distributing points to processors
Constructing processor meshes
Reading hexRef8 data : cellLevel
Reading hexRef8 data : pointLevel
14:08:25
Processor 0
    Number of cells = 7196
    Number of faces shared with processor 1 = 244
    Number of faces shared with processor 2 = 12
    Number of faces shared with processor 3 = 132
14:08:25      Number of processor patches = 3
    Number of processor faces = 388
    Number of boundary faces = 3954
Processor 1
    Number of cells = 7188
    Number of faces shared with processor 0 = 244
    Number of faces shared with processor 2 = 120
14:08:25      Number of processor patches = 2
    Number of processor faces = 364
    Number of boundary faces = 3958
Processor 2
    Number of cells = 7208
    Number of faces shared with processor 0 = 12
    Number of faces shared with processor 1 = 120
    Number of faces shared with processor 3 = 220
    Number of processor faces = 352
    Number of boundary faces = 4032
Processor 3
    Number of cells = 7200
    Number of faces shared with processor 0 = 132
    Number of faces shared with processor 2 = 220
    Number of boundary faces = 3996
Number of processor faces = 728
Max number of cells = 7208 (0.13892748% above average 7198)
Max number of processor patches = 3 (20% above average 2.5)
Max number of faces between processors = 388 (6.5934066% above average 364)
Time = 0
Processor 0: field transfer
14:08:25  Processor 1: field transfer
14:08:25  Processor 2: field transfer
14:08:25  Processor 3: field transfer
14:08:25
End
14:08:25  ./Allrun: Zeile 13: mpiexec: Kommando nicht gefunden.
14:08:25
OS: openSUSE Tumbleweed (KDE//usr/share/xsessions/plasma5)
Version: 0.21.0.31556 (Git) AppImage
Hash: 4091db47397f6e537a284f50c4f572545f3f30d0
  * CfdOF 1.21.6
Gruß Herbert
oliveroxtoby
Post by oliveroxtoby »
herbk wrote: Tue Mar 07, 2023 1:03 pm
14:08:25
You are missing MPI on your system. Try installing a package like 'openmpi'.
herbk
Post by herbk »
Hi Oliver
oliveroxtoby wrote: Thu Mar 09, 2023 6:14 am
14:08:25
it is, - at this this system openmpi1 und openmpi3 is installed. At openSuse there is a selector, which points to the openmpi to use, installed to.
I switched the selctor to openmpi1, may be thats the problem, i'l try if it works if i switch to a different version.
Gruß Herbert
herbk
Post by herbk »
oliveroxtoby wrote: Thu Mar 09, 2023 6:14 am ...
I tested several variants with mpi now:
Changing the mpi selctor to 1, 2, 3 or 4 (this mpi variants are availible at openSuse, at installing OpenFoam openSuse installs openmpi4 as default ) but got always the same error.
I try'd also reinstalling cfmesh and hisa after changing the mpi, - same error.
I not realy understand the code of that line 13 of Alwemake, but i guess it ponts to the locatoin where openmpi ist installed...
Where should be? Could it be that the presence of the mpiselector is't taken into account ?
Just some thoughts to fetch the problem...
Gruß Herbert
oliveroxtoby
herbk wrote: Thu Mar 09, 2023 3:08 pm
I don't have OpenSUSE to test with, but maybe this helps: https://en.opensuse.org/SDB:Openmpi_bin ... nd_in_PATH
Otherwise you may have to add the path to the executables manually to your system PATH variable.
herbk
Post by herbk »
Thank you oliver,
but it's something different, if i run "mpi-selector --list" i got shon my installed mpi's.
herbk@amd5700-lapi:~> mpi-selector --list
openmpi1
openmpi4
Things i noted at trying to find a solution:
If i set Parallel to true, but set the amount of cores to 1 i get the same error.
If i have the solver setting at "Parallel false", set it to true and change the amount of cores i get the warning
 failed to create compose table
But only if i do that the first time after opening the document, changing the amount again don't show it.
If i mesh the object, im in mind that all cores used, because the System monitor shows 100% processor load. Uses a process only 1 core, the System Monitor shows only about 8% (the amd5700 has a 6 cores / 12 threads kernel ).
Edit: after some other testings without succes, - adding the path to my .bashrc don't solve it to..
Gruß Herbert
herbk
Re: [Solved] Amount of used computing cores ?
Post by herbk »
gmsh
zlib-devel
openmpi1
openmpi1-devel
python3-paraview
Für OpenFoam:
Für OpenMPI
mpi-selector-menu
select openmpi1
(15.4 KiB) Downloaded 83 times
Gruß Herbert
lotnick
Post by lotnick »
After some successes in with CfdOf i got same error on line 13 of .allrun.
I decided to install newest MPI and now it works. ... So just letting you know. Thank you.
