Path comments tool
Re: Path comments tool
Ok, what I meant by broken is still there.
A path job created in 0.20 or older, when opened into 0.21, does not display the Job dialog box when clicked on.
The Job icon is not beside a list of operations etc but by itself.
When the Job is double clicked, the dialog does not open.
A drawing created in 0.21 does not display this behaviour.
- Screenshot from 2023-03-09 09-42-15.png (21.62 KiB) Viewed 990 times
See this pinned topic. There are two Python scripts which migrate old models to the new format.darrylb123 wrote: ↑Wed Mar 08, 2023 11:44 pm A path job created in 0.20 or older, when opened into 0.21, ...
My oh My, this is really going to cause problems.
We're a bunch of retirees learning to operate a home made CNC router and learning FreeCAD at the same time.
Changing all the models to work only on 0.21 is about 10 bridges too far. This will take some careful planning.
Definitely not going to do this until 0.21 is released.
Looks like no comments in gcode files for a while longer yet.
I would rather recommend the opposite: the earlier the better. A migration is another step, and unknown issues can occur.
Not sure what you are doing with the comments, but it is a trivial edit to add a comment as soon as the g-code file is created. Then it will be there for any subsequent users of that g-code on actual shop machines.darrylb123 wrote: ↑Thu Mar 09, 2023 5:13 am Looks like no comments in gcode files for a while longer yet.
When I need comments that is exactly what I do.
Gene
Something to consider with the g-code being shared among users:
https://wiki.freecad.org/Path_Sanity
Text entered in General>Job Description will show in the html file or the file can be edited in the usual ways.
Just a thought, use or ignore as suits your needs.
Run the attached macro within any file that is not printing the comments. It adds the 'Active' property to any Comment objects that are lacking it. This does the trick on my end using the FC version included below and a 'grbl' post-proccessor.darrylb123 wrote: ↑Mon Mar 06, 2023 10:36 pm ... Attached is a simple square with a path to route it out. A comment using the comment tool is added after the operation. The comment does not appear in the gcode output.
The comments in the gcode was working for 0.19 but has not worked for any of the 0.20 series.
Russell
Version: 0.20.2.29603 (Git)
* FC_SU
* freecad.gears 1.0.0
* Z_MacroStartup
- Make_Comments_Active.FCMacro
- Helper script to add 'Active' property to Comment objects lacking the same.
- (1.09 KiB) Downloaded 21 times
I would not call myself a "power user" but I've been using FC for years and know the ropes. I've just moved to 0.21 and I've had nothing but problems and breakage since I did. YMMV.And there are many power users around, who use this 0.21 version, without issues. GeneFC is one of them who also uses Path.
I don't mean to follow all updates, but we seem to have currently a very stable phase, which I can highly recommend.
Caveat Emptor !!chrisb wrote: ↑Wed Mar 08, 2023 11:55 pmSee this pinned topic. There are two Python scripts which migrate old models to the new format.darrylb123 wrote: ↑Wed Mar 08, 2023 11:44 pm A path job created in 0.20 or older, when opened into 0.21, ...
Please do not recommend that script without the warning that it is experimental, may trash your files and you should keep copies of everything before trying it.
The author says:
No warranties or guarantees implied, otherwise suggested, supported or otherwise offered. Use at your own risk. Please backup your originals before enjoying with a smile the attached script.
I'm puzzled. What do you want me to do?? As you quote yourself it's all written in the post containing the script.freman wrote: ↑Sat Mar 18, 2023 10:24 pm Please do not recommend that script without the warning that it is experimental, may trash your files and you should keep copies of everything before trying it.
The author says:No warranties or guarantees implied, otherwise suggested, supported or otherwise offered. Use at your own risk. Please backup your originals before enjoying with a smile the attached script.
