Flow testing simulation in FreeCad?
Moderator: oliveroxtoby
Does anyone know how to flow bench simulation in freecaad? I'm building cylinder heads for my personal use and I'm planning to simulate flows on my cylinder heads, anyone know how to? Thanks.
- Screenshot 2023-03-03 191040.png (30.36 KiB) Viewed 1193 times
- Screenshot 2023-03-03 191027.png (50.86 KiB) Viewed 1193 times
- Screenshot 2023-03-03 190928.png (42.9 KiB) Viewed 1193 times
- Screenshot 2023-03-03 190856.png (34.22 KiB) Viewed 1193 times
Re: Flow testing simulation in FreeCad?
It's done using an external workbench CfdOF along with it's dependencies, it's not a 2 minute job to get working. There's a dedicated subforum for CFD.
Moved from Open discussion.
Here you can find some tutorials for the CfdOF workbench:
https://youtu.be/OS4sbbBtZUw
https://youtu.be/JVO2kqO3D1Q
Ask here if you encounter any issues: viewforum.php?f=37
There are 2 CFD-Solvers for fluid-mechanics available in FreeCAD:
openFOAM (via cfdof-workbench) and Elmer-multiphysics (via FEM-workbench)
Some time ago there was a discussion in the german forum about optimizing an inlet-manifold
for an engine. This was really hard stuff.
viewtopic.php?t=29286&hilit=kolben&start=70
Some hints:
You must mesh a fluid domain, that means the inner part of your body where is nothing.
The construction of an "inverted" body is necessary.
Simulating the moving parts (piston) is possible, but not via the FC-GUI.
viewtopic.php?t=76425
For a realistic simulation you need an appropriate fine mesh, you are in the range of some mio cells.
Computing power is needed.
But lets give it a try...
Hello, I'm problems with cfdof dunno why and it won't run.
It has been hours and my back has been killing me
- adrianinsaval
ok let me check my crystal ball to see what problem you have...
it is impossible to give you any advice if you don't give any details
adrianinsaval wrote: ↑Tue Mar 07, 2023 1:29 pm ok let me check my crystal ball to see what problem you have...
