Kinematic Coupling Assembly3 strategies
Marodut
Post by Marodut »
Hello everyone!
I'm working on a kinematic mount where the base is locked into place and three spheres lock into the groove pattern.
I'm trying to use the most realistic set of constraints available in FreeCAD(Assembly3), but it seems I've run into a hiccup vith the "LineVertical" constraint.
For each of the spheres, i'm using the following set of constraints:
A_1/A_2 are "PointsPlaneDistance" constraints, they are meant to constrain the center of the spherical surface on a line that is equally distant from both of the groove surfaces.
As the distance is equal to the radius of the sperical surface, this makes the surfaces of the groove tangent to the sphere itself, thus allowing the shpere to "roll" freely along the groove.
As I'm following a Top Down modelling approach, i would like to derive the informations that are necessary to model the frame that connects the sphere blocks from the placement of the blocks themselves, instead of locking them to another body.
To manage the blocks aligment i'm using the "LineVertical" constraint, as "Elements" for the LineVertical constraint I'm using planes and axis from the origin of the ParDesign bodies.
Everything seems ok, but, if you try to moove the sphere block with the "Axial move part" command, the body moves where it should't be able to.
I have two questions for you all:
1) Is there a more efficient/effective set of constraints to achieve the same goal?
2) Have I understood properly how "LineVertical" works ? Am I missing something?
Thank you :)
Example file:
Kinematic_Coupling.FCStd
(344.36 KiB) Downloaded 51 times
Version: 0.21.30265 (Git)
Hash: c35244e74f326a04c5bcab31e984742db582ac78
Python 3.8.13, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
  * Assembly3 0.11.3
  * Behave-Dark-Colors 0.1.1
  * CurvedShapes 1.0.4
  * Curves 0.6.5
  * Dracula 0.0.2
  * ExplodedAssembly
  * fasteners 0.4.54
  * fcgear 1.0.0
  * freecad.gears 1.0.0
  * OpticsWorkbench 1.0.9
  * sheetmetal 0.2.61
FBXL5
Re: Kinematic Coupling Assembly3 strategies
Post by FBXL5 »
Line vertical is dealing with the projection of a line onto a plane. The projection is constrained vertical i.e. along the y axis in relation with the plane's coordinate system.
Multi parallel could be used to link the backside of the spherical object and XY_Plane@Base@ to keep its axis perpendicular to the plane.
Hope this leads into the right direction to further explore the Assembly3 constraints.
jpg87
Post by jpg87 »
Marodut wrote: Fri Mar 03, 2023 10:46 am...
I wanted to test your file, but I lack information to fully understand what you want:
1- what relationship should there be between the spheres and the "carrier"?
2- must the 3 spheres be able to move independently of each other?
(the answer to the previous question may answer this one)
bambuko
Post by bambuko »
Hi @Marodut
tried looking at your file and... there is a problem with sphere body.
Shape must be a wire, edge or compound. Something else was supplied
Sphere_body.FCStd
(38.82 KiB) Downloaded 46 times
jpg87
Post by jpg87 »
@bambuko
I had the problem in the version of @realthunder where I had to rebuild the sphere, but this error does not appear in the master version.
Marodut
Post by Marodut »
bambuko wrote: Sat Mar 04, 2023 9:59 am Hi @Marodut
Happened the same to me with linkstage3 branch, it's like the function doesn't recognize the construction line used as axis of revolution.
Deleting the function and making it from scratch solved the issue for me.
jpg87 wrote: Sat Mar 04, 2023 9:55 am 1- what relationship should there be between the spheres and the "carrier"?
My goal is to be able to tune the constrain strategy to gain the type of insight that i'm interested in.
AS3 is very powerful, but it can be a struggle to put what you have in mind into a sequence of commands.
I'd like to bounce ideas and share test results with oter users to "separate the wheat from the chaff".
I'd like for both the placement and the geometry of the carrier to be driven by the characteristics of the sub assembly composed by the blocks and the base.
In the image below there's an example:
The severity of the tilt can indicate which kind of washer is best suited to accomodate both bodies or what kind of tolerances are necessary to achieve the desidered funcionality.
A similar line of reasoning can be applied to the length of the carrier spokes, to the angle of the V groove, to the diameter of the spherical surfaces, etc ...
(373.55 KiB) Downloaded 45 times
Marodut
Post by Marodut »
FBXL5 wrote: Fri Mar 03, 2023 2:21 pm Multi parallel could be used to link the backside of the spherical object and XY_Plane@Base@ to keep its axis perpendicular to the plane.
MultiParallel rocks !! :D
It can deal with imputs of different nature: (circular line and three surfaces)
How does it work? can someone share the math behind it ?
jpg87
Post by jpg87 »
Marodut wrote: Mon Mar 06, 2023 1:34 pm...
Personally, I only use the constraints from the main toolbar :
Whenever there is a particular plane, shape symmetry for example, I use PlaneAlignment (with possibility to set a distance with "Offset" or more parameters), PointInPlane or PointsPlaneDistance as you did to make tangent your vee-grooved sphere...
The SameOrientation constraint seems to manage the parallelism of the normals to the planes considered, but also the orientation of these normals. The MultiParallel constraint seems more flexible and does not take into account the orientation of the normals.
I couldn't find any more explanation than https://wiki.freecad.org/Assembly3_Workbench.
Marodut
Post by Marodut »
Hi everyone! I've been playing with a different approach.
Instead of relying on the properties of 3D surfaces, i'd like to attach the references as close to the coordinate system as possible.
I've choosen to use the "PlaneCoincident" constraint; to locate the items I've used the offset properties of the contstraint itself.
OffsetX and OffsetY manage the distribution of the polar pattern, while OffsetZ manages the tangency between the sphere and the angled surfaces.
Screenshot from 2023-04-22 12-30-22.png (32.67 KiB) Viewed 1456 times
The function that generates OffsetZ value, refers to a plane geometry problem:
Screenshot from 2023-04-22 12-31-46.png (23.46 KiB) Viewed 1456 times
I've split its components into a spreadsheet, i hope it makes it clearer.
Setting the orientation for each of the blocks has proven to be troublesome:
locking the "Angle" property ~~results~~ (brings with it/"esprime") in a snapping behaviour, I believe it's related to these posts
* Auto relax
* Solver errors
* sin/cosin uncertanty
I have also tried to use "vertical line" constraint, but i can't derive the constraint element from an origin plane, it only works with surfaces generated by features, which isn't great for TPN reasons.
Screenshot from 2023-04-22 12-34-51.png (54.95 KiB) Viewed 1456 times
What do you think of the workflow? Does anyone spot any problems or issues?
Thank you all :) .
Kinematic_Coupling_locked_angle.FCStd
(314.05 KiB) Downloaded 34 times
(334.23 KiB) Downloaded 38 times
OS: Pop!_OS 22.04 LTS (pop:GNOME/pop)
Version: 0.21.0.31695 (Git) AppImage
Hash: 64caea207394bb05587c8ffb29b7a3e8696d24df
  * Assembly3 0.11.4
  * fasteners 0.4.54
  * ExtremeProDark 2.6.4
  * Dracula 0.0.2
jpg87
Post by jpg87 »
Marodut wrote: Sat Apr 22, 2023 10:43 am The function that generates OffsetZ value, refers to a plane geometry problem:
The advantage of constraints is that there is no calculation to be made.
As I said before, simple constraints are enough.
Problem, on the version
Version: 0.21.0.32929 (Git)
Hash: 1dcc58c4b1c51c50215639ca58326f6b69867743
Locale: French/France (fr_FR)
  * Assembly3 0.11.4
  * BOLTSFC
  * Curves 0.6.8
  * DynamicData 2.46.0
  * fasteners 0.4.2
  * fcgear 1.0.0
  * QuickMeasure 2022.10.28
  * Render 2023.2.3
"DatumPlanes" are wrong when converted to constraint "Elements".
planes needed.png (67.18 KiB) Viewed 1397 times
planes transferred to Elements.png (89.54 KiB) Viewed 1397 times
In the branch of @realthunder the problem does not arise.
Version: 2023.131.26244 +5365 (Git)
Branch: LinkDaily
Hash: 73c4ca254c5de8849d104973482e98399fb24863
Python version: 3.10.8
Qt version: 5.15.4
Coin version: 4.0.1
OCC version: 7.6.3
The file I attached assumes that the 3 spheres move independently of each other.
You haven't defined the movements that "Carrier" should have either.
Kinematic_Coupling_jpg87_Ls3.FCStd
(401.11 KiB) Downloaded 42 times
