Problem starting a transient simulation
Moderator: oliveroxtoby
Budahn
Post by Budahn »
Hello, ultimately im having this problem with almost all my simulations, i tried to make the simpliest sim possible but im still having error and i dont know why. Maybe is something in my computer, can you run this with normality guys?
25.5: OpenFOAM IO error: --> FOAM FATAL IO ERROR: OpenFOAM IO error: --> FOAM FATAL IO ERROR: OpenFOAM IO error: --> FOAM FATAL IO ERROR: OpenFOAM IO error: (openfoam- file:
25.6: Simulation exited with error
16:00:26  [2]
[0]
[1]
[3]
[2]
[0]
[1]
[3]
[2]
[0]
[1]
[3]
(openfoam-
(openfoam-
(openfoam-
(openfoam-
2012
2012
2012
2012
[2]
[0]
[1]
[3]
Wrong token type - expected scalar value, found on line 0: word 'None'
Wrong token type - expected scalar value, found on line 33: word 'None'
[2]
[0]
[1]
[3]
[2]
[0]
[1]
[3]
file:
file:
file:
file:
IOstream.mixture.specie.molWeight
C:/Users/Ramiro/AppData/Local/Temp/case/constant/thermophysicalProperties.mixture.specie.molWeight
 at line
 at line
 at line
 at line
0
33
0
0
[2]
[0]
[1]
[3]
[2]
[0]
[1]
[3]
    From
    From
    From
    From
Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&)
[2]
[0]
[1]
[3]
    in file
    in file
    in file
    in file
lnInclude/Scalar.C
lnInclude/Scalar.C
lnInclude/Scalar.C
lnInclude/Scalar.C
 at line
 at line
 at line
 at line
154
154
154
154
[2]
[0]
[1]
[3]
FOAM parallel run exiting
[2]
[0]
[1]
[3]
16:00:26
job aborted:
[ranks] message
[0] application aborted
aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 0
[1] application aborted
aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 1
[2] application aborted
aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 2
[3] application aborted
aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 3
---- error analysis -----
[0-3] on DESKTOP-9LB0K9U
C:/Program Files/ESI-OpenCFD/OpenFOAM/v2012/msys64/home/ofuser/OpenFOAM/OpenFOAM-v2012/platforms/win64MingwDPInt32Opt/bin/buoyantPimpleFoam aborted the job. abort code 1
16:00:26
ForumSimple.FCStd
(17.06 KiB) Downloaded 40 times
Raedchen_im_System
Re: Problem starting a transient simulation
Post by Raedchen_im_System »
@Budahn : Your simulation is everything but a "simple" simulation :shock: :
A transient simulation with a compressible medium is quite difficult to handle.
If you are running a simulation with a compressible medium, I would recommend to use 1e5 Pa (= 100 MPa) as pressure for initializing the field and for the outlet. In your simulation, you are using 10 Pa on the inlet and on the outlet, and you specified a velocity of 2 m/s on the inlet and on the outlet. 1 boundary condition (speed) on the inlet and 1 boundary condition on the outlet (pressure) are enough. I would recommend to you to use 2 m/s on the inlet and define 0 Pa (no boundary condition) on the inlet. On the outlet, I would recommend a speed a 0 m/s (no boundary condition) and the static pressure of 1e5 Pa.
As far as I know, a potential flow is not feasible for a compressible flow. For this reason, I would recommend to define a speed of -2 m/s for initialising the simulation.
In case an error occurs, you should always press the "edit" button in the simulation menu. In the log file of the buyont-pimplefoam, you find that there was an error in line 33. The error is caused by the file "thermophysical properties" in the directory "constant":
thermophysica properties.jpg (25.24 KiB) Viewed 675 times
This error means that the mol weight was not defined. If you click one time on the check box "compressible" in the fluid properties and then click again, this error disappears and your simulation will run.
Last edited by Raedchen_im_System on Thu Mar 02, 2023 9:20 pm, edited 1 time in total.
Budahn
Post by Budahn »
Thank you so much, when i say a "simple" simulation i was trying to say that the geometry was simple :lol: thanks for your help :D
