Hello All,
When I use Draft_Edit with manually typing the coordinates FreeCAD crashes.
If I use mouse to pick the coordinates everything works fine.
Please find the attached video.
FreeCAD version: FreeCAD 0.21.0 Revision: 32166 (Git)
I can provide additional logs or information if needed.
Thanks.
Draft edit crashes when typing coordinates
Re: Draft edit crashes when typing coordinates
I suspect it is the same issue I reported here: viewtopic.php?t=73045
Unless I've missed some recent change, there is no known proper fix for it but as explained in the linked thread, there is something that can be done to mitigate the problem (=solves the problem for me in practice). I suppose I could create an issue + PR with that mitigation during the upcoming weekend unless someone else beats me to it. (And create another issue for fixing the problem properly.)
In anticipation of "I can't reproduce that" posts, it seems that the faster the computer (and the less load) you have, the less likely the problem is to occur, it's timing sensitive. On the faster of the two machines I tested with, I had to slow things down artificially.
Thank you for the reply.
Yes. It is exactly the same issue.
I can work around the problem by not hitting the enter right away but to use "Tab" key to change the focus to "Enter point" button and than hitting the enter. This workaround works consistently but the permanent fix would be nice
I am able to reproduce the problem, but not consistently. It may be hard to solve. I'll put this on my ToDo list anyway.
Version: 0.21.0.31917 (Git)
Hash: 4639283b459f9ff9093e289908cc003db8745b82
Python 3.10.9, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: English/United States (en_US) [ OS: Dutch/Netherlands (nl_NL) ]
