I need some help as it seem that I cannot come any further myself.
Task is that I have a cone with a pressure of air of 100 kPa on the inlet (large area of the cone); 95 kPa on the small area of the cone.
In real life a pressure drop like this would let the fluid flow from the high-pressure-area to the low-pressure area.
Meshing went okay.
First question: is it altogether possible to simulate this pressure drop situation?
I have tried many different adjustments in the parameters but all to no avail.
Writing the case is okay:
0.0: Checking dependencies...
0.0: Case writer called
0.2: Matching boundary conditions ...
0.4: Case written successfully
Running the solver gives an error code:
17:52:31 Time = 0
17:52:31
Processor 0: field transfer
17:52:31 Processor 1: field transfer
17:52:31 Processor 2: field transfer
17:52:31 Processor 3: field transfer
17:52:31
End
17:52:31 ERROR: Failed to post close command error 1726
ERROR: unable to tear down the job tree. exiting...
17:52:32
My FC Information:
* Cfd
* CfdOF 1.21.6
* CfdOF.bak 1.21.4
* Curves 1.21.6
* Curves.bak 0.6.6
* dodo 1.0.0
* fasteners 0.4.54
* freecad.gears 1.0.0
* Plot 2022.4.17
* sheetmetal 0.2.61
The file:
Thank you for any advice.
Kind regards,
Helmut
Flow through Cone with pressure drop
Moderator: oliveroxtoby
Re: Flow through Cone with pressure drop
Yes, of course. Pressure difference between inlet and outlet is commonly used in CFD.
I don't get any errors when I submit the analysis from the attached file. Check your CfdOF installation and try submitting some test analysis (something really basic like a pipe).
- Raedchen_im_System
Hello @r.tec ,
on my computer, your simulation model runs without errors. After 173 iterations, the solution converged. I used the CfdOf-workbench 1.21.4 and ESI-OpenCFD v2206.
When I look on your screenshot, it looks like you have an issue with a phyton-file. The next message tells you to look into your log-file. You can find the logfiles from ESI-OpenFoam pressing the "edit"-button in the Cfd-Solver-Menue: Your message refers to the directory C:\Users\Helmut\AppData\Roaming\FreeCAD\Mod\Cfd. Did you use the Cfd-Workbench or the CfdOf-Workbench?
- oliveroxtoby
From the below post:
oliveroxtoby wrote: ↑Tue Jan 15, 2019 8:51 pm
[*] On Windows, there can be issues with conflicting MSMPI versions. This is usually indicated by the following error:The best remedy is usually to uninstall and reinstall the OpenFOAM (or BlueCFD) package, making sure to run the installer with administrator privileges if possible. If asked, answer 'yes' to reinstalling MSMPI.Code: Select all
ERROR: Failed to post close command error 1726 ERROR: unable to tear down the job tree. exiting...
Please provide all the information requested in this post before reporting problems with CfdOF.
...yes, reinstalled MS MPI: FreeCAD runs through. Fine!
Now I get an error-message from Paraview:
File "<string>", line 53, in <module>
File "C:/Program Files/blueCFD-Core-2020/AddOns/ParaView/bin\Lib/site-packages\paraview\servermanager.py", line 424, in __ConvertArgumentsAndCall
retVal = func(*newArgs)
TypeError: ResetCamera argument 1: expected a sequence of 6 values, got bool
Do not know how to remedy it but it seems not to hinder further work with Paraview.
Thanks a lot!
Thanks a lot!
- oliveroxtoby
Which version of Paraview is this?r.tec wrote: ↑Sat Mar 04, 2023 4:55 pm ...yes, reinstalled MS MPI: FreeCAD runs through. Fine!
Thanks a lot!
Version 5.6.2 64-bit
Qt Version 5.12.3
Qt Version 5.12.3
