PartDesign Shapebinders: the property "Support" and Attachment clash
Hello!
The Shapebinders in PartDesign have the property Support, but also Attachments have them. So you can not add any Attachment on it. Because when you add an Attachment on Shapebinders, in the Attachment you have the list of Shapebinder geometries, even when it is on an other group.
Is it possible to rename this property in the Shapebinders?
Greetings
user1234
Greetings
user1234
Re: PartDesign Shapebinders: the property "Support" and Attachment clash
Agree with that. Shapebinder must be attach..able. With it was no planned?
As with the link version.
- Capture.JPG (30.18 KiB) Viewed 1837 times
- adrianinsaval
Please create a github issue about this
Nice. But a few question:
- is it possible to open old file properly after the merge?
- is then also the normal shapebinder necessary? Because then the subshapebinder can do much more as the shapebinder. The only thing what is then missing is a dialog and the property trace support.
Greetings
user1234
Yep, I added handleChangedPropertyName() impls for that. It worked as expected on a project I created with a release version.
Agreed, but I didn't try to unify them. I did fix the problem for both normal and sub binders though.
- adrianinsaval
Suggestions for how the property should be called are welcome
Shape (according to Part booleans)adrianinsaval wrote: ↑Wed Feb 28, 2024 2:36 am Suggestions for how the property should be called are welcome
Base (because it tastes a bit like a BaseFeature)
Profile (according to PartDesign features)
Originals (according to PartDesign patterns)
Source (I'm very sure it is used somewhere)
- adrianinsaval
Shape is already a property of all Part::Feature derived objects (anything that's brep essentially), although it's normally hidden by default. That one can't be used.
Profile doesn't seem right to me, sometimes you use binders on whole solids or just on edges or even just on points.
Any of the others seem good to me, I had also proposed the name Source on the github PR
