My recreated document has problems with the detail frame on top:
- Snip macro screenshot-7a3bd0.png (16.29 KiB) Viewed 1134 times
It occurs with simple and complex sections. Recompute doesn't change the result
This is the output from the report window:
19:45:35 View is finding hidden lines
19:45:35 SectionView is making section cut
19:45:35 Detail is making detail shape
19:45:35 ComplexSection is making section cut
19:45:35 Detail001 is making detail shape
19:45:35 View has finished finding hidden lines
19:45:35 View is extracting faces
19:45:35 SectionView has finished making section cut
19:45:35 SectionView is finding hidden lines
19:45:35 View has finished extracting faces
19:45:35 SectionView has finished finding hidden lines
19:45:35 SectionView is extracting faces
19:45:35 SectionView has finished extracting faces
19:45:35 Detail has finished making detail shape
19:45:35 Detail is finding hidden lines
19:45:35 ComplexSection has finished making section cut
19:45:35 Detail001 has finished making detail shape
19:45:35 ComplexSection is finding hidden lines
19:45:35 Detail001 is finding hidden lines
19:45:36 ComplexSection has finished finding hidden lines
19:45:36 ComplexSection is extracting faces
19:45:36 ComplexSection has finished extracting faces
19:45:37 asCircle - OCC error - gp_Dir() - input vector has zero norm - while approx spline as circle
19:45:37 Geom::baseFactory - unknown error occurred while making spline
19:45:37 Detail001 has finished finding hidden lines
19:45:37 Detail001 is extracting faces
19:45:37 Detail001 has finished extracting faces
These Lines are displayed in red:
I hope this helps somehow.
OS: macOS 10.15
Version: 0.21.0.31917 (Git)
Hash: 4639283b459f9ff9093e289908cc003db8745b82
Python 3.10.9, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: C/Default (C)
* Reinforcement
* fcgear 1.0.0
* Render 2023.1.0
* fcgear.backup1662890180.767765
* fasteners 0.4.54
* CurvedShapes 1.0.4
* sheetmetal 0.2.61
* Help 1.0.3
* Curves 0.6.6
* Assembly3 0.11.4
