(SOLVED) Zoom to fit working plane?
thomas-neemann
Re: (WORKAROUND) Zoom to fit working plane?
Post by thomas-neemann »
mario52 wrote: Fri Feb 24, 2023 5:16 pm ...
hi mario
Thank you for your work, but
if I use it correctly it doesn't work with me
mario52
Post by mario52 »
Hi
home work fine ... sorry
Version: 0.21.0.31917 (Git)
Hash: 4639283b459f9ff9093e289908cc003db8745b82
Python 3.10.9, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
mario
thomas-neemann
mario52 wrote: Fri Feb 24, 2023 6:41 pm ...
there is probably a misunderstanding here. this video might clear it up
https://www.youtube.com/watch?v=CGGjZP41lxg
phpBB [video]
mario52
Post by mario52 »
Hi
thomas-neemann wrote: Fri Feb 24, 2023 6:56 pm
try the new code in my precedent post
mario
thomas-neemann
mario52 wrote: Fri Feb 24, 2023 9:01 pm ...
when I run it as a macro I get this
Python 3.10.8 | packaged by conda-forge | (main, Nov 22 2022, 08:36:16) [GCC 10.4.0] on linux
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> # App.setActiveDocument("Unbenannt3")
>>> # App.ActiveDocument=App.getDocument("Unbenannt3")
>>> # Gui.ActiveDocument=Gui.getDocument("Unbenannt3")
>>> App.closeDocument("Unbenannt4")
>>> ### Begin command Std_New
>>> App.newDocument("Unbenannt")
>>> # App.setActiveDocument("Unbenannt4")
>>> # App.ActiveDocument=App.getDocument("Unbenannt4")
>>> # Gui.ActiveDocument=Gui.getDocument("Unbenannt4")
>>> Gui.activeDocument().activeView().viewDefaultOrientation()
>>> ### End command Std_New
>>> FreeCAD.DraftWorkingPlane.alignToPointAndAxis(FreeCAD.Vector(0.0, 0.0, 0.0), FreeCAD.Vector(0, 0, 1), 0.0)
>>> FreeCADGui.Snapper.setGrid()
>>> Gui.runCommand('Std_DlgMacroExecute',0)
when i copy paste it into the python console i get this
>>> # 24/02/2023
>>> # adapted for the workingPlane v2
>>> #https://forum.freecadweb.org/viewtopic. ... 20#p407855
>>> #[FEATURE REQUEST] Life-size view ?
>>> from pivy import coin
>>> #gridEvery = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Draft").GetInt("gridEvery") # 20
>>> #gridSpacingF = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Draft").GetFloat("gridSpacing") # 5
>>> gridSize = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Draft").GetInt("gridSize") # 100
>>> gridSpacingS = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Draft").GetString("gridSpacing") # 10.0 mm
>>> gridSpacingI = int(gridSpacingS.split(",")[0])
>>> Gui.activeDocument().activeView().viewTop()
>>> cam = Gui.ActiveDocument.ActiveView.getCameraNode()
>>> cam.position.setValue(App.Vector(0,0,0))
>>> vpSize = Gui.activeView().getSize()
>>> invHeight = min(vpSize[0], vpSize[1])
>>> vpDpi = Gui.getMainWindow().physicalDpiX()
>>> cam.height.setValue((invHeight*25.4/vpDpi)+(gridSize*gridSpacingI))
>>> cam.height.getValue()
in both cases the grid disappears
mario52
Post by mario52 »
Hi
I don't know !
here it work fine , here with 2 different document open
paste in Python console or as a macro
mario
thomas-neemann
mario52 wrote: Sat Feb 25, 2023 11:29 am ...
can it be that it runs differently under windows than under linux?
thomas-neemann
if you turn on toggle axis cross it works, if you turn it off again it still works until freecad restart
thank you very much
mario52
Re: (SOLVED) Zoom to fit working plane?
Post by mario52 »
Hi
thomas-neemann wrote: Sat Feb 25, 2023 12:12 pm if you turn on toggle axis cross it works, if you turn it off again it still works until freecad restart
good also (after config and restart) with or without axis
OS: Ubuntu 20.10 (KDE/plasma)
Version: 0.21.30492 (Git) AppImage
Hash: b4578fb3eae842eb510a1bc055d07d369a67ce94
good day
mario
thomas-neemann
mario52 wrote: Sat Feb 25, 2023 7:46 pm ....
strange. 0.21 doesn't work here either
Version: 0.21.0.31917 (Git) AppImage
  * 3D_Printing_Tools
  * Curves 0.6.6
