[SOLVED] weekly-builds not updated
It seems weekly-builds are not updated since 2023-02-16
FreeCAD_weekly-builds-31917-2023-02-16-conda-Windows-x86_64-py310.7z
FreeCAD_weekly-builds-31917-2023-02-19-conda-Windows-x86_64-py310.7z
FreeCAD_weekly-builds-31917-2023-02-23-conda-Windows-x86_64-py310.7z
/Best Regards BG
/Best Regards BG
- adrianinsaval
Re: weekly-builds not updated
@looo it looks like the conda build is failing to upload all the packages: https://dev.azure.com/sppedflyer/feedst ... ew=results maybe an expired token or something like that?
Still not updatedadrianinsaval wrote: ↑Fri Feb 24, 2023 2:40 am @looo it looks like the conda build is failing to upload all the packages: https://dev.azure.com/sppedflyer/feedst ... ew=results maybe an expired token or something like that?
FreeCAD_weekly-builds-31917-2023-02-26-conda-Windows-x86_64-py310.7z
Looks rather like some quota is exceeded:adrianinsaval wrote: ↑Fri Feb 24, 2023 2:40 am @looo it looks like the conda build is failing to upload all the packages: https://dev.azure.com/sppedflyer/feedst ... ew=results maybe an expired token or something like that?
https://dev.azure.com/sppedflyer/feedstock-builds/_build/results?buildId=665&view=logs&j=9c5ef928-2cd6-52e5-dbe6-9d173a7d951b&t=20c71c51-4b27-578b-485d-06ade2de1d00&l=35066 wrote: ...
File "/Users/runner/miniforge3/bin/anaconda", line 10, in <module>
sys.exit(main())
File "/Users/runner/miniforge3/lib/python3.10/site-packages/binstar_client/scripts/cli.py", line 158, in main
binstar_main(command_module, args, exit,
File "/Users/runner/miniforge3/lib/python3.10/site-packages/binstar_client/scripts/cli.py", line 138, in binstar_main
return args.main(args)
File "/Users/runner/miniforge3/lib/python3.10/site-packages/binstar_client/commands/upload.py", line 315, in main
package_info = upload_package(
File "/Users/runner/miniforge3/lib/python3.10/site-packages/binstar_client/commands/upload.py", line 243, in upload_package
upload_info = aserver_api.upload(username, package_name, version, file_attrs['basename'], fd,
File "/Users/runner/miniforge3/lib/python3.10/site-packages/binstar_client/__init__.py", line 572, in upload
self._check_response(res)
File "/Users/runner/miniforge3/lib/python3.10/site-packages/binstar_client/__init__.py", line 227, in _check_response
raise ErrCls(msg, res.status_code)
binstar_client.errors.BinstarError: ('Storage requirements exceeded (3221225472 bytes). Payment is required to add a file. Please go to https://anaconda.org/binstar.settings/billing to update your plan', 402)
Failed to upload due to Command '['anaconda', '--quiet', '--show-traceback', '-t', '/var/folders/24/8k48jl6d249_n_qfxwsl6xvm0000gn/T/tmplz9ox66t/binstar.token', 'upload', '/Users/runner/miniforge3/conda-bld/osx-64/freecad-0.21.pre-py310hb68df51_86.conda', '--user=freecad', '--channel=dev']' returned non-zero exit status 1.. Trying again in 10 seconds
Using BINSTAR_TOKEN for anaconda.org uploads to freecad.
INFO:binstar:Using Anaconda API: https://api.anaconda.org
- adrianinsaval
Ah makes sense, should the FPA pay for this? can older versions be removed to make space or something like that? how much do we need? Do you have info @looo ?
Maybe its time to retire windows-x86_64-py38.7z as there is WO that works, been using it for quite some time now.adrianinsaval wrote: ↑Sun Feb 26, 2023 5:57 pm Ah makes sense, should the FPA pay for this? can older versions be removed to make space or something like that? how much do we need? Do you have info @looo ?
If that helps!
- adrianinsaval
what is WO?
I suspect "work around".
I have been using that as well, and I have seen zero problems with Python 3.10. (I use Windows 7, 10 and 11 somewhat interchangeably, depending which computer is convenient.)
Gene
Still no update:bgma1961 wrote: ↑Sun Feb 26, 2023 1:21 pmStill not updatedadrianinsaval wrote: ↑Fri Feb 24, 2023 2:40 am @looo it looks like the conda build is failing to upload all the packages: https://dev.azure.com/sppedflyer/feedst ... ew=results maybe an expired token or something like that?
FreeCAD_weekly-builds-31917-2023-03-02-conda-Windows-x86_64-py310.7z
