Incremental rotation of parts
Vagulus
Post by Vagulus »
I am making a flexible drive coupling. There are two yokes which must interlock.
230223 Misaligned Flexible Coupling Yokes.png (30.46 KiB) Viewed 1408 times
When I insert the second yoke it is about 22.5° out of mesh. I cannot rotate it except in increments of 90° - that is to say, "I have not yet found a way to rotate a part except in increments of 90°."
There must be a way.
Would someone please enlighten me? Thanks
"It is much harder to simplify than to complicate."
Joseph Kimble
bambuko
Re: Incremental rotation of parts
Post by bambuko »
Have you thought/tried typing over the default 90deg, to replace it with the desired angle?
PS it might help if you mention which assembly workbench you are using?
Vagulus
Post by Vagulus »
Sorry about that
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Locale: English/New Zealand (en_NZ)
  * Assembly4 0.12.2
  * BOLTSFC
  * Curves 0.5.1
  * dodo
  * fasteners 0.3.46
  * parts_library
Using Assembly 4.
You can't overtype the Rotate Buttons.
Joseph Kimble
ppemawm
Post by ppemawm »
Vagulus wrote: Thu Feb 23, 2023 2:37 am "I have not yet found a way to rotate a part except in increments of 90°."
Select the Part or Body Link in Model. Use the Assembly > Attachment Offset in the Property View. Define the Axis and Angle.
You may have to expand the Ellipsis in the Attachment Offset field to get the correct axis in the Placement panel. Use Apply Incremental Changes as first step. Then define axis and angle. It is not so intuitive but with some experimentation you will likely get the hang of it.
Note that there is an Assembly4 0.12.4 update.
"It is a poor workman who blames his tools..." ;)
Vagulus
Post by Vagulus »
There is an 0.12.5 update! :D
  * Assembly4 0.12.5
  * BOLTSFC
  * Curves 0.5.1
  * dodo
  * fasteners 0.3.46
  * parts_library
However, you've got me.
230224 Rotating Part 640.510.png (109.02 KiB) Viewed 1212 times
As far as I can fiigure out (I could find nothing in the Assembly4 Documentation) you can only set one angle. Even then, I can't figure out how you apply that angle of rotation to a specific axis - nothing I cahnge changes anything. I am completely mystifies as to how I would rotate the Bossed yoke 180° on the Z-axis and 15° on the X-axis.
I will greatly appreciate any help here.
Joseph Kimble
Zolko
Post by Zolko »
Vagulus wrote: Thu Feb 23, 2023 2:37 am When I insert the second yoke it is about 22.5° out of mesh. I cannot rotate it except in increments of 90° - that is to say, "I have not yet found a way to rotate a part except in increments of 90°."
create an intermediate LCS that you attach to the 1st part, rotate that intermediate LCS by the amount you need, and attach the second part to that intermediate LCS
Vagulus
Post by Vagulus »
Ahh! Rotate it on insertion.
Thanks
Joseph Kimble
ppemawm
Post by ppemawm »
Vagulus wrote: Fri Feb 24, 2023 2:16 am There is an 0.12.5 update! :D
Thanks for the heads up.
As in all things FreeCAD there is more than one way to do things. You can also rotate the original sketch. Or, rotate the body LCS. Or,...etc.
Vagulus wrote: Fri Feb 24, 2023 2:16 am As far as I can fiigure out (I could find nothing in the Assembly4 Documentation) you can only set one angle.
ppemawm wrote: Fri Feb 24, 2023 12:25 am You may have to expand the Ellipsis in the Attachment Offset field to get the correct axis in the Placement panel. Use Apply Incremental Changes as first step. Then define axis and angle. It is not so intuitive but with some experimentation you will likely get the hang of it.
Please see attached file and try experimenting.
Assembly4_Placement.FCStd
(47.22 KiB) Downloaded 36 times
See also https://wiki.freecad.org/Placement
Version: 0.21.0.31850 (Git)
Hash: d8d3bb8120ad139cf1eb2acf0be0ae6c297ac7f3
Python 3.10.9, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
  * Assembly4 0.12.4
  * fasteners 0.4.15
  * freecad.gears 1.0.0
  * QuickMeasure 2022.10.28
  * Render 2022.2.0
Vagulus
Post by Vagulus »
Thanks for that. Lots of things I didn't know existed. :D
Joseph Kimble
